Question about Canon MX700 Office All-In-One InkJet Printer
Can I get my Canon MX700 printer to print if the color ink is out but the black ink is full.
No because the printer will state you are out of color ink and will stop your printer right away
Posted on Nov 15, 2010
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
MX700 printer does not print in black
you have a clogged jet and ink has dried inside i reckon... the only other thing it could be is the message from the logic board (its motherboard) inside printer isnt getting to the print head or print head itself has malfunctioned - i would suggest to fix but it would probably be cheaper to buy a new one but dont give up.... sometimes they do work if you print pages even tho there is no flow and the heat may dislodge blockage if there is one... But heres a video that may help...
May 06, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Printer won't print. Thinks ink is out. Wireless won't print and neither wired usb won't print. Happened so suddenly.
most printers will not print if color ink has run out and vise versa with the black ink, you cant bypass this, however reinstall the drivers/software for the printer it maybe be on that side
Apr 27, 2010 | Canon MX700 Office All-In-One InkJet...
I use my MX700 only for black & white matters. It sometimes refuses to operate, informing me that my color cartridges have run dry. How do I overcome this?
Unless you have chosen to print in "true black" where only the black ink cartridge is used, your printer automatically will use some inks from the color cartridge to make black. (The reason given is so that your color cartridge will not dry out and cease to function when you do need it for color).
You did not provide your operating system. If you can find your printer name listed in "Control Panel" (usually in "Printers and Faxes"), right click the name and choose "Properties". See if you can find an option to print only using the black ink cartridge.
I hope this helps!
Dec 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink does not print. Color works fine.
The print head is probably blocked then. You may be able to get a cleaning cartrige if you look online. Failing that, it will probably need a service.
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Ink Cartridge
how do you set the ink tank on a mx700
Feb 25, 2009 | Canon MX700 Office All-In-One InkJet...
Printer Pixma MX700 will only print in color not black and white?
Try going into Control Panel and click on printers. Normal 0 when the next window comes up, Click on MAINTENANCE, the Properties page will come up and this is where you can do the NOZZLE check/clean and other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Jan 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing black ink
some canon printers come with a utility program that has a whole host of troubleshooting programs.
if yours came with this, try looking in it for a nozzle cleaner or head cleaner utility.
im thinking the generic ink may have gummed up the printer nozzles.
if that doesnt work, take a Q-Tip and clean the heads and nozzles on the cartridge with denatured alcohol (~$10; pick it up at local pharmacy maybe? i got mine through the local grocery stores pharmacy).
let me know if that works for you. got a couple other ideas.
Aug 15, 2008 | Canon PIXMA MX700 All-In-One InkJet...
COLORED INK
if u read the manual carefully it says that the color ink is also used up along with black ink when printing .it is also used up in keeping the print heads clean. thank u for asking this question .
Jun 06, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
148 people viewed this question
old marine
old marine
