Question about Ovens
Replace doors on jenn air oven with stainless
I have a jenn air double wall oven W256W. I read your post answering koskinner's question. Is it possible to replace my white doors with stainless steel and my control panel with another color, preferably black? thanks.
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Posted on Jun 29, 2008
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
Jan 09, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn- Air Model W256W
hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Apr 01, 2008 | Ovens
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
318 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
