Question about Ovens
Just bought a Bush electric fan oven AE6BFS. The glass door gets extremely, dangerously, hot. I wired the unit into my electric hob just like the previous oven.
BADBOYJAY
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
  • 63 Answers
SOURCE: beko s512 oven wont heat up light not on hob works
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Posted on Mar 15, 2009
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Posted on Feb 21, 2010
  • 3 Answers
SOURCE: built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Posted on Sep 23, 2010
I need a wiring diagram for bush oven switch ae6bfs
Request the diagram directly from Bush.
Jun 05, 2016 | Ovens
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Nov 08, 2014 | Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
Does the bush AE6BFS single fan oven require hardwiring or can it plug into normal socket
Generally speaking, a single oven can be used from a normal 13 amp socket.
If you are not sure, check the power used by the oven on the rating plate, as long as it does not exceed 3kw, then itt is o/k to use from socket.
If more than 3kw, then it will need to be hard wired.
Oct 25, 2010 | General Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
139 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
