Question about Kodak EasyShare C713 Digital Camera
My kodak lens errer problems so help me please model c713 lens err 20e 1,0.0
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2010
My Kodak easy-share len is stuck. what do this Len error 20e 1,0,0 means?
There are some steps which can be followed which may resolve this problem which as follows,
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Sep 13, 2014 | Kodak Cameras
Lens won't retract
Hello
The error you are receiving, is a lens error. If the camera is still in the warranty period, i would suggest that you take it back to point of purchase as soon a possible.
Unfortunately, it is a very difficult task to take apart your camera to get to the lens. The problem is probably that the lens itself dislocated from the socket it runs in. Can you hear a faint noise as well?
THe best advice i can give you is to take your camera in for repairs. I have worked on Lens errors myself, and, if not done correctly, you will end up with a totally useless camera.
This repair will cost you about $40 - $50 including labor.
Kodak will also give you the trade in option, where you will be able to trade in your camera, and buy a newer model for 30%- 40% cheaper.
I really hope this can be of help, i know how much that Kodak moment is worth!
Please feel free to let me know if you need any further assistance.
Kind regards
Andrea
Mar 04, 2010 | Kodak EasyShare C713 Digital Camera
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Lens error 20e,1,0,0
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 24, 2009 | Kodak Easyshare C813 Digital Camera
I have the Kodak C513, My cameras lens is stuck, everytime I turn it on my lens will not come out and on the screen it says lens error 20e,1,0,0 please help
Sounds like impact. Try putting new Good batteries in. If that doesn't work, you can contact Kodak to see where the local "authorized" service center in your area is, I know of 2 in South Florida.
305-653-7355
Apr 15, 2009 | Kodak EasyShare C513 Digital Camera
Lens Problem
Okay, Kodak is a load of **** if they won't allow warranty on an item that doesn't retract. And I got an SanDisk SD Card like you, and on most of my pictures it says, "FILE FORMAT UNRECOGNIZABLE." You should Email Kodak and talk to them about that warranty, or at least make them tell you how to fix it. What a jyp!
Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
149 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
