Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
I have Model# 6G40PV-40F.When i went for vacation I turned to Vacation.Now I'm back and try to start water heater it start and heat the water then quit sending light code 4-2.I can only restart again by resetting unit then all happened again.
3 Suggested Answers
  • 454 Answers
SOURCE: i have a rheem water heater and it has went into
Do you have the model number? There is usually a temperature control knob on the heater that you turn to VAC, that just keeps it lit. Usually, setting it to 120°F is adequate.
Posted on Apr 06, 2010
  • 5089 Answers
SOURCE: What's your problem?my richmond hot water heater model 6g40pv shut of and is flashing fvd interphase failure. how do i reset it
Tom W must have been 'recommended answer' from past answers, and not live answer.
What did Tom's answer say?
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Posted on Mar 22, 2013
I have a Bradford white water heater- how do I check if it is on vacation mode?
The gas valve dial, which is in front of the heater near the bottom, will say "Vacation" mode. Just line up the pointer with the word vacation. Some models no longer use the word "Vacation", replaced with "Low or Warm". It will be the setting just before "OFF"
See Pics (inside blue box) answers your questions:
Feb 13, 2015 | Water Water Heaters
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Keep getting a f9 and f10 code . how do we fix what do they mean
1) F9 and F10 appear to be element failure/ Call for service
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#element
2) Copy following link for more GE Hybrid Geospring resources:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
3) Call GE and they will tell you to call for service:
1-888-443-4394
4) 2009 service manual says you can clear fault codes by pressing Filter, Lock, Vacation button sequentially within 3 seconds. Scroll to clear all fault codes using arrow keys. When that is highlighted, press Filter, Lock, Vacation again.
Others report this does not work, so it may depend on model. Or maybe buttons need to be pressed simultaneously.
5) GE does not want folks working on their own water heater.
Do not buy expensive water heaters you cannot fix yourself.
Average service call for GE heat pump is $400 which helps defeat anticipated savings from buying hybrid.
Jan 26, 2013 | General Electric GE GeoSpring Hybrid Water...
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The control says on vacation and the heater won't stay on.
there should be little screw or knob you can turn if off of vacation and turn it back to a hotter setting
Apr 12, 2011 | White Rodgers Water Heaters
I have a rheem water heater and it has went into vacation mode and i have no hot water. how do i get it out of vacation mode
Apr 06, 2010 | Water Heaters
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
368 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
