Question about Insignia Televison & Video
Jumping or fluttering picture when playing - Insignia Televison & Video
  • 790 Answers
Hi...
Jumping picture scene or sounds.. are made by defective Pick up Lens.. or Flex ribbon Wire!!! Replace a new one!!! How old your unit?
Thanks!!!
Posted on Jun 19, 2008
How do I prevent film flutter on a Bell & Howell 253 AX movie projector?
run the film thru a couple of times and set the tenssion mid way
to another real and back
this will re- tenssion the film to your setup
make sure all guide sprockets are free runnings
and good belts etc
well weight setup machine
a film should be spooled first a few times too get it right too the machine ....
most films now get sticky
there are product to treat old films
my adivce is while you can watch it back it up in some why
Dec 11, 2014 | Cameras
Picture flutters
If this is a projection TV and it shrinks and expands its a common issue with certain Philips TV sets. Sites like www.TvRepairKits.com have the kits to fix this.
Mar 30, 2012 | Televison & Video
I play a tape in my Sony SL-5200 Betamax VCR. It plays normally for about 5-10 minutes and then the picture starts fluttering which lets out this loud buzz on the Hi-Fi audio track and cuts it out to mono....
It could be some kind of tracking problem. The cause could be dirt on the tape head, or perhaps something worn such as a drive belt etc. Check to see if it gets worse or better with the cassette nearly at the end of the tape or at the start of it. Indicating a tape tension problem, on the reels or drive.
Jul 28, 2011 | Sony Televison & Video
Picture rolls and the tracking is off.
do the heads need cleaning? sounds like the heads are seriously out of alignment? take off the vcr cover get a philip scrdrv. put tape in. and play. theres an AC head just to the right of the drumhead. jiggle it around gently. u may have to adjust those 3 screws (precison) to put it back in proper adjustmant. also take the tapes u used in that vcr. open the top flap and inspect. are there marks? is there a line going the bottom portion of the tape. if so , it definitely is out of alignment.
Aug 14, 2009 | Philips Televison & Video
50UX18B Hitachi Projection TV
Good Day, monarchdr272;
Sounds like you may have a bad comb filter. Yes things can be repaired. Good Luck, big IRISH.
Aug 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
115 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
