Question about Price Pfister Ashfield Single Control Lavatory Faucet ...
How can I increase water flow from this faucet? Is there a water flow restrictor that can be removed?
2 Suggested Answers
  • 62 Answers
SOURCE: no water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
Posted on Jun 05, 2009
How do I get more water pressure from my american standard shower set
Hi Fran:
Most shower faucets now are equipped with flow restrictors. It is possible with some units to remove the flow restrictor plate from the shower nozzle. It has to be dis-assembled to do that.
Regarding the lack of hot water, that would usually be a different problem and will be related to the hot water source.
Hope this helps.
Dec 30, 2015 | American Standard Plumbing
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
I just installed a new Shelton Pfister pull out kitchen faucet that whistles when turned on. How do I remove the flow restrictor?
I don't think it is the flow restrictor. I am guessing your water pressure is on too high. That would cause the whistling.
Elisa Jed ' http://www.kookaburrakitchens.com
May 14, 2014 | Plumbing
Remove flow restrictor on KWC Faucet
We have a KWC 10.501.012.000 - Systema kitchen faucet and after installation the water pressure was much lower, even after adjusting the faucet's limiter screw to "minimum". We ultimately decided that the reduced flow was unusable and called back the plumber service. They sent out a different guy this time and he knew where to find and how to remove another of the faucet's built-in limiters (it has three, apparently).
I saved the removed water limiter parts. I hope this picture of them can you or anyone else with this same problem remove the limiter and get strong flowing water again...
Jul 02, 2012 | Dmm Plumbing
Just had K-10433 installed. Would like to increase flow. Is there a removeable restrictor?
Yes there is a water saver disk in the aerator. It is a small disk about 1/2" diameter with a very small hole in the center.
When you take the aerator apart pay attention to the parts order so they are put back in the same order minus the water saver disk.
Mar 07, 2011 | Kohler Forte Single Control Kitchen Sink...
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
I want more water pressure/volume from my sigmatherm shower faucet. Is there an ''inside the wall'' volume adjustment?
If you are looking for more flow from your showerhead, remove the showerhead and check the following.
1. Check for debris inside the connection nut.
2. See if you can locate a flow restrictor inside the connection nut. There are a few different types, but most can be removed with little effort.
3. If your showerhead has small rubber nozzles on the face, rub them with your finger while the water is flowing. This will loosen and wash away any sediment that may be present in them.
This picture shows one type of restrictor that is used in showerheads.
Jan 12, 2010 | Plumbing
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Blanco purus II poor water pressure
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Jan 30, 2009 | Blanco Plumbing
Price Pfister Ashfield Single Control Lavatory Faucet ... Logo
257 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
