Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a side by side PSS26LSRE ice maker and water do not work and the bottom half of fridge and freezer are cold but top half warm also vegetable crisper freezing fruit and veggies.
5 Suggested Answers
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
  • 311 Answers
SOURCE: Crisper is freezing
This is a bad damper and it would need to be replaced. Try turning the freezer warmer until you can get this fixed and move up your stuff from the drawers.
Posted on May 28, 2010
mreid542
  • 166 Answers
SOURCE: Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Posted on Jul 14, 2010
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
