Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
TV is 4 years old. Not used very much. Watching TV yesterday, everything normal, great picture, etc.. TV goes off. Checked outlets,cable, etc.. Could not get TV power back on. Any suggestions ? No life, lights of any signs of power when I switched outlets ? Thank you. Jack Biggane
  • 10,594 Answers
Question heading shows it is Sharp LC-37G4U tv and if power indicator dose not lit if tv plugged in that means power supply board got defective and need to be replaced.
Required power supply board is available with ShopJimmy.com for $79
Click above link to view power supply board image and price info.
If you are handy with electronics stuff repair then can replace power supply board by yourself OR call local tv repair shop to do this job.
Hope these info will help you.
Let me know if you have additional question.
Thanks
Posted on Nov 15, 2010
Ac#13-0120-2171. We have no picture on shaw cable TV
Try checking the A/V Cables. They could be Defective or loose.
Dec 01, 2009 | Motorola HDT101 DTV Receiver
Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
TV channel shows up behind the picture while watching dvds!
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 24, 2009 | Dynex DX-L32-10A 32" LCD HDTV
No picture, no sound
sounds like the main board maybe going out or is gone and the lamp may have went as well
Jul 20, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Jan 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Older projection tv won't turn on.
id replace the tv its 15 years old and past the livlihood they usually have. it would cost more in parts to repair it than to go out and buy a new one. im sure you probably already know that though. have the tuner checked but i dont think it will save the tv but if it comes on when the cable box isnt hooked up then the problem could be in the tuner. its hard to tell. the tuner is about 100.00
Dec 29, 2008 | Televison & Video
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
May 31, 2008 | Televison & Video
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Mar 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
223 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
