Question about Amana PTC153B50AM Split System Air Conditioner
No display on control board. Looks like no power? Circuit Breaker OK, tried unplugging/plugging back in, tried reseting the reset/test on the plug.
  • tkulwicki Nov 16, 2010
    There's power at the outlet. Is there anyway I can confirm its the board before I purchase a new board?
    Can I jumper around the board to be sure the rest of the system is working?
  • 3,083 Answers
You'll have to get someone to measure the voltage in, and find out where it's being lost. You could have a bad reset switch on the plug side, and the next step is to make sure voltage is getting to the unit. There's usually a transformer that knocks the voltage down, and a power circuit that rectifies it to dc, so it will take a bit of troubleshooting to figure it out.
Get someone who knows how to use a vom to help you figure this out. It could even be a fuse.
Good luck, and be careful when measuring voltages.
Posted on Nov 17, 2010
  • 10,865 Answers
Hello tkulsicki. Begin by checking to be sure that their is power at the outlet where you are plugging in the appliance. If you do not have a tester, the least expensive way is to go to the hardware store and buy a light bulb socket with pigtail and a 15 watt bulb. Use this to see if the outlet works. That is the first step. After that, assumming that the outlet is live, your circuit board is the next suspect item.
If there is no power at the outlet but the circuit breaker appears to be on, then most likely the circuit breaker itself is bad and needs to be replaced. Joe
Posted on Nov 16, 2010
The console will not work with the treadmill. Cannot start or change settings but is getting power.
Hi Nancy,
If you have tested the power point ~ for example: plugged in a vacuum cleaner and you have power ~ yet when you plug the treadmill in, you have no console display, there is a 99% chance you have a faulty lower control board...
Thank you,
Ben.
#treadmillrepair #treadmillbelt
TreadmillBelts.com.au HealthEquip.com.au GYMWORKS.com.au
Dec 01, 2014 | Exercise & Fitness
Had power go off now er flashing on all burners can not reset
It's possible that you had a surge when the power returned that scrambled the controller's brain. Try disconnecting power and reconnecting to restore normal operation. Disconnect power by unplugging the stove from the wall or switching off the breaker that controls it at your main circuit breaker box. Wait a minute or two, then plug the stove back in or turn the circuit breaker back on. If the stove does not work after this, you may need a new controller board.
Aug 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
F1 flashes half way through the wash
Hi...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this IMAGE...
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2Plus shows F1 Error at start - Plug unplug and try again machine up pressing start continues to so F1 Error
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore HE2 Plus Front Load Washer
Have a kenmore he plus 2 front loader it flashes f-01 i have unplugged it for a hr. and then plugged it back in about a half hr later and it still flashes
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Will not power on
ok check the glass fuse inside the washer it will be on the circuit board
shaun
Aug 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Only 1 cycle works,the towel and sheet cycle. the others wont fill machine with water. also up until a week ago f1 was coming up all the time. would have to unplug machine to try and reset.
Mar 07, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My HE 2Plus Has an 01 error code, unplugged washer, waited plugged it in again still unable to clear code
Mar 02, 2009 | Kenmore Washing Machines
Amana PTC153B50AM Split System Air Conditioner Logo
131 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
