Question about Microwave Ovens
I have just put in a new Dual element with limiter and a new control panel.The contol panel was to fix the 2 ovens as the readings it was displaying on the control panel kept saying it was the oven sensors.The dual element hasn't been working for some time so i got a new one.The wiring was slightly different from the old one to the new one.the old had the black wire going from the limiter to the centre of the 3 prongs,on the new one it is connected automatically.the difference is the limiter is connected to the nearest prong other than that it's all the same.What could be the problem now?.Is is the switch?
  • mwhelan1975 Nov 15, 2010
    It is not a microwave oven it is a matag oven model #mer6770acw
  • Microwave Ovens Master
  • 12,061 Answers
Well it sounds to me as if there is NO connection, as the contacts are NOT lined up?
You need to find out what Pins the element is actually on, using a meter set to OHMS meter the element, and you should get a resistance, as long as it's NOT a short, that's OK for now,OK, now note the Pins. mark one Hot the other Cold. I use a red phase and black neutral, pen (or in USA use Black, Phase, White neutral)
Now CAREFULLY with the power On element on, check that OUTPUT and see what pins there is voltage on... and which connection is neutral.
So the Voltage, must go to ONE side of the element, the "Hot" side, the Other side, the "Cold" side simply connects to the neutral return.
As long as you are sure you have it correct, it doesn't matter how you connect those two points together, as long as it make good contact and is insulated and isolated from everything else.
usually when it says Oven sensor, it means the Thermistor temperature sensor inside the oven. These often go "Open Circuit" and stop the elements from working, because the "Controller" will not be "Allowed" to power them up. They are fairly simple to replace.
Also it may pay to obtain a service manual for your exact make and model, this will have schematics etc, to help.
Basically to work, you must have an unbroken path from the mains Phase IN, to the Hot side of an element, the Cold, simply goes to neutral, return. Any "Control" simply switches the Phase, ON/OFF.
The various Controllers simply in-disbursed between, IN & HOT side of the Element, with their contacts, in the Phase Circuit to the Hot side of the Element, across the element and then to Neutral, circuit complete..
Posted on Nov 15, 2010
  • 10,865 Answers
Hello. Whenever you get a newly designed part for an older appliance you must refer to the original wiring diagram and the wiring diagram for the new part, and also test the wires to see which are hot and which are neutral. Until those things occur, other considerations are premature. Joe
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
LED not working
see this causes and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE Advantium 120 Convection/Microwave Oven
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
Contol Panel replacement
We have the full service manual for this model and have uploaded it to our site here to help you.
It has step-by-step disassembly instructions.
Also, a
t our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If your new controller develops display trouble too, and it's not backed by a one year guarantee, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 10, 2009 | Sharp R-1500 Microwave Oven
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
