Question about Electrolux Epic 6500 Vacuum
Repair my Electrolux 2100 cannister vacuum cleaner
The bag full light comes on and shuts the motor off even with a new bag installed. I have the new control to change it out but can not figure out how to get the outer shell open so I can get inside to change the part.
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
I have a 2100 Electrolux cannister vac. I have just noticed an odd odor (similar to burning) and the protection mode light went on. Can you advise of steps to take to rtrouble shoot and what might be...
The motor is probably burning out, or has. Smell the exhaust port. If the odor is especially strong, here, then that's the problem. You'll need to take the vacuum to the nearest Aerus Electrolux store for definite diagnosis and repair/replacement of parts.
http://www.aerushome.com/storelocator/index.cfm
Feb 01, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux 2100 does not turn on. the light bag full comes on even with a new bag
The bag might not be seated properly or you are using the wrong type bag.Try reseating the bag.
Jan 20, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Full Bag Shut-off Comes on With New Bag and No Hose
The control valve has gone bad. This is the dial that you move on the top of the vacuum that has little indents on it.
You cannot do anything to bypass this problem from outside the machine.
This is not a repair that you can make yourself. You should look in your local yellow pages for Aerus (new name for electrolux) under vacuum cleaners, or go to www.aerusonline.com and find your local dealer. It is not too expensive to have fixed, it is a common issue with later model electroux vacuums.
You can try a test to see if it the valve. Remove the bag from the vacuum, look at the back of the bag holder near the motor, in the upper right or left depending on your model. You will see a very small hole 1/16 or an inch or so. Put a piece of tape of some sort to close off the hole. Replace the bag, turn on the vacuum, if it is a bad valve, the tape will override the bag full action, and the vacuum will run.
It is not advisable to run the vacuum this way since it will overheat, damage the thermostat, and can destroy the motor. A motor will cost over $200.00, the valve can be replaced for a lot less….
Jul 29, 2009 | Electrolux Epic 6500 Vacuum
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
471 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
