Question about Toshiba Satellite A105 Notebook
Using External Wireless Card with an Internal wireless laptop
Okay, I'm not the greatest when it comes to computers, but I do know a few things about them. Is there any way to use my Verizon wireless card with my internal wireless. The only port I can see is for the Express card.
My laptop is a Toshiba Satellite A305-6825 that I just recently bought at Best Buy and I am in the midst of moving and don't have the time to see the Geeks.
  • 4 more comments
  • Breezy52 Jun 19, 2008
    Okay, I understand now, but do I insert the Verizon card in the Express card port?
    Do I insert the Verizon Card into the Express port, or do I need an adapter?
    Thank you everyone for your assistance. Yes, I got it working, no thanks to my husband hanging over my shoulder telling me "What to do"! LOL
    This is going to be the first place I look for assistance on ANY product. Keep up the great work.
    Okay, I thought it was fixed. The slot for the card has a weird configuration. Think L shaped living/dining room, where it is longer on one side (left) than the right side. I DO feel that I need an adapter of some sort.
    HELP!!!!! I am moving today, and there is no internet until next week. I am already in withdrawls!!
    Okay, more info for you. I am using my own notebook as the "main frame". My husband who has the Verizon card has not received his notebook from his company yet. Must be snail mail!! So therefore, I am the "sole" user of this card.
    Any comments from the experts?
  • Breezy52 Jun 20, 2008
    Thank you Benimur! You have completely solved my problem. I will be off to the store tomorrow to pick up the USB to USB Card. I need it immediately or else I would order on-line.
    Many thanks, you're the best.
    President:
  • 1,257 Answers
To create a working connection:
1. In the Network Connections folder, right-click Wireless Connection, and then click Properties.
2. Click Configure, and then on the Advanced tab, configure your wireless network by using the available configuration options. The available options and option names may vary depending on the driver manufacturer.
The following list describes the basic configuration options:
• Service Set Identifier (SSID): This setting will match the configuration of your wireless access point or router. If you do not have an access point, this value will be the same on all the computers that are in your wireless network.
• Wireless Equivalent Protocol (WEP) or Encryption: Disable WEP on both the access point and in these properties for testing purposes.
• Mode or Network Type: If you have an access point, set this option to Infrastructure. If you do not have an access point and you are connecting computer to computer, set this option to Ad-Hoc.
• Data Rate: Set this option to Auto or to 11 Mbps.
• Power Save: For troubleshooting, set Power Save to Off or to Disabled. After the connection works correctly, you can change this setting.
3. After you configure these options, click OK to save your changes.
4. Test your connection. If a red "X" appears over the connection icon in the Network Connections folder or if you cannot connect, continue troubleshooting.
5. Click Start, click Run, and then type devmgmt.msc in the Open box.
6. In Computer Management, double-click Services and Applications, and then click Services.
7. In the details pane, right-click Wireless Zero Configuration, and then click Properties.
8. In the Startup type box, click Disabled, and then click OK.
9. Quit Computer Management, and then restart the computer.
With this configuration, you can connect to the wireless network if the other network configuration is correct. If the Wireless Connection icon appears in the notification area as a working connection, the wireless connection will work.
For Toshiba wireless troubleshooting tips
http://uk.computers.toshiba-europe.com/Contents/Toshiba_teg/EU/GENERIC/files/C_05_Wireless-Troubleshooting-EN.pdf
Posted on Jun 19, 2008
  • 2 more comments
  • Deeps . Jun 19, 2008
    If you experience issues when you try to connect to the network,
    double-click the Wireless Connection icon in the Network Connections
    folder to view the connection status. In the Connection status, there
    is a signal strength meter that you can use to verify the strength of
    the signal between computers.
    Strong signal
    If you still have trouble connecting but the signal strength is good, a
    different network configuration issue may be preventing communications.
    To resolve this issue, use standard TCP/IP troubleshooting techniques.
    Weak signal
    If you still have trouble connecting and the signal strength is not
    good or no signal is received, try the steps in the "Drivers That Do
    Not Support the Wireless Zero Configuration Service" section. If the
    method that is described in that section does not resolve the issue,
    contact the manufacturer to determine if the wireless network adapters
    and the access point are working correctly.
    Insert the Verizon Card into the Express port,no need for adapter...
    Thank you for using fixya technical support.
    Just check the manual on how to remove the plastic cover ,and after removing it insert the card into it..
    it can be removed by using nail..
    Congrates...
    Thanks for using fixya technical support.You have a great day
  • 1,879 Answers
Using External Wireless Card with an Internal wire - 5fa34b4.jpg this works on it's own. like it is needed to connect to verizon wireless internet. your internal on the other hand is designed to work with a home networking equipment such a wireless router (one that is connected to the internet via DSL / Fiber / Cable / etc).
  • 6 more comments
  • monk3ybidzness
    monk3ybidzness Jun 19, 2008
    Yes, you need to insert it to work
  • monk3ybidzness
    Hope this answers your question:
    Yes you can use that Verizon Wireless card with that Laptop.
  • monk3ybidzness
    It is a PCMCIA card and laptops have PCMCIA ports (err hopefully all NEW laptops have one)
  • monk3ybidzness
    Did I posted the correct image ? anyone ?
  • monk3ybidzness
    Insert it please . . .
  • monk3ybidzness
    Thanks Benimur
    Yes that's where it should go or feel free to look at the other side or at the back.
    Keep us posted and thank you for using our service.
    FixYa for all your troubleshooting needs.
  • monk3ybidzness
    Thank you for using our service.
    FixYa.com - Consumer Electronics support, repair, manuals, faq, problems and solutions.
  • monk3ybidzness
    Hello again !
    If the slot looks weird and you feel like an adapter is needed, go to the nearest geek store.
    Brigadier General:
  • 6,966 Answers
The Verizon wireless card should work straight out as long as the IP configurations are correct. In effect you would have two (2) wireless networking with the Verizon as active/enabled/connected. Additionally, you can also turn off the built-in Toshiba high-speed 802.11a/b/g wireless LAN to save on resources. As long as you direct your Toshiba to connect to the Internet using the Verizon, there should be no issues. Of course, installation/configuration instructions are normally available with and in a CD that came with the Verizon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 3 more comments
  • Louie  Role
    Louie Role Jun 19, 2008
    Hi again,
    ohms posted an image of the card. It should plug in straight to the side slot/opening. In some instances there might be a detachable cover or a "dummy" card inside that should be removed.
  • Louie  Role
    Ho adapter needed and yes it needs to be plug in to the PCM/CIA port on the left side as shown below.
  • Louie  Role
    Sorry for the typo, that should be "No adapter needed".
  • Louie  Role
    That's what FixYa is for and glad to be of assistance. Personally, appreciate the rating too.
  • Louie  Role
    Hi again,
    It would seem that your Verizon Wireless card uses the ExpressCard/54 (54 mm wide, in an L-shape shown in the middle in the below image).
    Your Toshiba laptop was designed to accomodate all sizes including the the Card Bus size (bottom of image). To my knowledge, only the new Toshiba Satellite P and X 200/205 series of laptops and desktop replacements have an ExpressCard/34 slot since April 2007.Your Verizon in ExpressCard/54 form factor will fit into both 34 mm and 54 mm card slots via a diagonal guide in the rear of the 54 mm slot that guides the card to the connector. Alternately, you can get an adaptor to USB similar to the one shown below
    (available http://www.synchrotech.com/product-usb/i..." target="_blank" rel="nofollow" >here) or this one
    http://www.everythingusb.com/hardware/re..." target="_blank" rel="nofollow" >here if you are finding it difficult to align you Verizon. Should you be interested, http://support.dell.com/support/edocs/sy..." target="_blank" rel="nofollow" >here is an informative discussion of Express Cards fitted to laptops.
    Hope this be of additional information that addresses your concern. Again, good luck.
  • 426 Answers
Yes you can
  • Lee N.
    Lee N. Jun 19, 2008
    ooops sorry about that, Yes you can you can install and have the either one be the default then when one is gone the other will work... you can also share the 3g connection with your other computers via the internal card, let me know what you are trying to do and i would be more than happy to help you :)
  • Lee N.
    Lee N. Jun 19, 2008
    yes insert it into the port and it should install automatically if the software is setup properly
Does my hp pavillon s7310n slimline PC have wireless internet capabilities
Not built in, but you can pick up a USB adapter such as this one for cheap: moz-screenshot-1.pnghttp://www.walmart.com/ip/CNet-CQU-906-Wireless-N-PicoUSB-Dongle/15571889?sourceid=1500000000000003142050&ci_src=14110944&ci_sku=15571889moz-screenshot.png
Mar 01, 2011 | HP Pavilion s7310n (EN996AA) PC Desktop
Computer crashes
A few things can cause this.
  • Shorted wireless card
  • Weak power plug/connection
  • Weak regulator (inside the computer)
  • Hardware driver issues. You should get a blue screen
Having done a restore eliminates the bad driver really. So we should expect one of the others. If it is a weak power supply, connector it should shutdown when using the cd drive
Try another wireless card if possible.
Jan 24, 2010 | Gateway 4542GP Notebook Computer With...
Is there a wireless card in the toshiba satellite 1415-s173?
Go to Control Panel > System > Device Manager
Under Network Adapters you would be able to locate wireless card if its there in your system.
Sep 19, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Presario V6110US wireless is inop
There are 2 ways you can work this.
- One of course is the External Wireless card you currently have
- Second, is to replace the internal card. Most laptops ahve a VERY easy to getat wireless card, and you can purchase the card on ebay for as low as 9 dollars plus shipping. Find what model laptop you have, and i'll even make a reccomenation, and show you how to access the wifi card.
May 01, 2009 | HP Compaq Presario V6110US (882780849006)...
Sony VAIO internal wireless driver causes computer to lock up
There is a possibility you have a faulty wireless card. I would go with a external PCMCIA wireless card. Don't forget to disable the internal wireless card in the BIOS.
Feb 16, 2009 | Sony VAIO PCG-K23 Notebook
Compaq Presario F500 Laptop Internal Wireless Card
You should be able to use a usb wireless
just make sure it's compatible with your pc
What exactly is wrong with the internal one
did you repair person actually look at it
Jan 13, 2009 | Computers & Internet
I have a Compaq Presario F500 laptop that is about 6 months old and the internal wireless card is going out. It takes about 2 hours of restarting before it actually turns green and picks up the signal. I...
You could try using a wireless adapter that connects through usb but the connection is not as strong. Otherwise I would try to buy an internal wireless card which is just installed into a PCI slot on your motherboard.
HP dv1000 laptop and internal wireless modem
Although you have internal wireless, you are capable of attaching an external wireless device. For example, you could attached a D-Link WUA-1340 USB Wireless G adapter (http://www.dlink.com/products/?sec=0&pid=477), or, if you have a PCI port, you can use a Linksys WPC300N Wireless-N Notebook adapter (http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1319686869B07). Either device with any brand will work just like your internal wireless. In fact, because you chose to use an external device, you may get a better wireless signal. Because internal wireless devices are inside the computer, it is more difficult to received a signal than with an external device.
Apr 20, 2008 | HP Pavilion dv1000 Notebook
NETGEAR WIRELESS
reset the router...see if the laptop will see your access point..if it sees any access points at all....if it dosent then reinstall the wireless card. what version of windows are you using ?
Feb 28, 2008 | NetGear DG834G Router
How can i get my wireless rooter to work
Wireless cards come in many different forms: external USB devices, internal PCI Cards desktops, external PC (PCMCIA) Cards for laptops, and internal mini PCI cards for laptops.
What type of computer are wanting to make work with your wireless router? Laptop or PC?
Feb 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Toshiba Satellite A105 Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
