How to programme PT plus (British Gas) thermostat for 'holiday' - can see button but reverts to 'twice a day' after pressing.
2 Suggested Answers
  • 10 Answers
SOURCE: Programmable Thermostat = Much Higher Bill?
You say your bill increased by as much as 40%. You must understand, this has been a much colder winter than usual as well. Not to mention, if your unit has not been properly serviced to the proper temprature rise anually you will be wasting gas everytime it operates. On over 90% of installed units they are operating over their designed temperature rise and wasting fuel and money for the end consumer. This is why it is very inportant to have you equipment service twice a year, beginibg of winter for the heater and begining of summer for the AC. But, more inportantly, it must be done PROPERLY...
Call me and I will explain the procedure...
Richard (Rick) Drennan
Global HVAC Distributors
Ruud Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
Posted on Jan 05, 2009
Need to clear programmable settings
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation
denbrcvrefwaaaaasuvork5cyii=
Nov 11, 2013 | Proselect PSTS21P52 Programmable 2 Stage...
Change factory set date on thermostat
This is just general information for most thermostats. Press the set button until the date comes up. Press the up or down temp. buttons to where you want it. Press the run button to lock it in. I hope this helps.
Nov 11, 2013 | Honeywell Programmable Thermostat Heater
Can't set temperature
first go turn breakers off at indoor unit or if gas turn switch or unplug for thirty seconds.should be a hold button on thermostat , set desired temperature and press hold allow five minutes to go by.listen doen anything at all happen at unit.
if nothing happens after five minutes remove sub-base from wall and at the thermostat jump with a wire the r terminal and the white terminal see if it comes on if so you got a bad thermostat most likely.
Dec 02, 2011 | Honeywell Programmable Thermostat Heater
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
I can not change the thermostat setting on the unit. Whenever I try to change it, it reverts back to the previous setting.
The thermostat will display the current tempature in the room. When you press the buttons to change the tempature and you see it change back it is probably going back to the room tempature display but still keeping the temp you set it at. Also make sure the "hold" feature is set or the temp you choose can change at different times during the day due to the programmable features built into the thermostat.
Sep 08, 2009 | Honeywell Heating & Cooling
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C with no display
I pressed the reset button in error and the display just would not return o no heating or hot water. Nothing tripped on the board and all wires and the unit itself showed power coming through.I got it working again by sheer determination.
What I did
I took the unit from the base plate and opened the front panel to see circuit board. It has 4 clips and it all goes back together easily.
What I did.Time taken 15 minutes.
The tiny rubber reset button was collapsed, perhaps maintaining the 'off' situation.
I moved a tiny wire from touching the side of the battery.Perhaps not important but it didnt look right.
When i remounted the unit it lit up beautifully.
So the solution lies in 1 or all of these 3.
If it happens again I will try
1. simply remove the unit from its base plate and remount to see if that is all it takes.
2. Open the front and check the reset button isnt collapsed and stuck.
3. Just move that little wire from leaning against the battery -(least sure of why this might help)
hope this might help someone else
Catherine - a determined blonde lady
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
648 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
