Question about Honeywell Water Heaters
HI, I'm having trouble lighting my honeywell water heater. The directions say to push down the knob and push the igniter until pilot light is lit, then wait for the LED light to flash green before you can switch the knob to your prefered settings. well the pilot light lights but the LED light will not flash, and if you try to switch the knob to your setting the pilot light just goes out again.
  • Honeywell Master
  • 3,087 Answers
Check the pilot is clean not a short flame so its missing the sensor. Also check flame sensor and connection .
Posted on Aug 12, 2017
4 Suggested Answers
  • 8404 Answers
SOURCE: Having trouble getting the pilot light lit: A O
Thermocouple may be bad. Replace it to rule it out as the trouble. Expect to pay less tahn $10.00
Posted on Oct 14, 2009
  • 119 Answers
SOURCE: pilot light lights and stays lit until you turn
Sounds like this is the gas regulator giving the the problems, i would call a local plumber to service this . gas and flame is very dangerous.
Posted on Mar 28, 2010
  • 68 Answers
SOURCE: hi im having trouble lighting
after pilot lite you got to hold it down for 45 sec before you can turn it on..if you still having trouble get a qualify technician to relite it.
Posted on Aug 10, 2010
Where is the pilot lite to the hot water heater
There is a small (usually ) aluminum slide door. You need to air out the immediately area of any possible gas, then turn the knob on the regulater to pilot, hold the button down for a minute or so then use a long match to light the pilot light inside that little door. Hold lit matches up to the little tube until it lights. Then turn knob to temp.
Apr 06, 2016 | Water Water Heaters
How can we ignite the pilot switch
The directions are on the inside cover of the water heater as well as on the paperwork you received with the unit.
If you have none of these, get the make and model number of the unit and look it up on the internet.
General directions to light a gas appliance:
1.Turn the switch to, "Off"
2.Remove the 2 panels at the base of the unit.
3 Identify the pilot device.
4.Get a long lighter or match on a stick that reaches the pilot.
5.Turn the gas knob to the, "Pilot" position
6.Light the match and put it next to the pilot while pressing down the knob
7. Keep the knob pressed for about 45 seconds after the pilot lights
8. Let go of the knob so it's in the, "up" position
9. Turn the knob to the, "On" position
-the water heater should fire up in under a minute.
10. Put the metal panels back into position.
Jul 14, 2014 | Honeywell VR8200C6008
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
GAS WATER HEATER PILOT WILL NOT LIT
assuming you mean you have electric ignition, DO NOT try to lite with a flame of any kind. make sure gas is on, while pushing knob turn to PILOT hold knob down for appr. 10 seconds while still holding knob down,push ignter. you may have to do this proccess afew times. if this doesnt work, call a pro. gas appl. can be extremily dangerous
Dec 21, 2012 | Water Heaters
Hi im having trouble lighting my water heater and turn the water to hot. it says push and hold the knob and repeatedly press until pilot ignites.
Aug 09, 2010 | Honeywell Water Heaters
Pilot light has gone out how do i relight it?
Hi .. look at the control valve on the burner .,. there is a knob you can turn. It has markings for pilot and run, or something like that. turn the knob to pilot and push and hold it in. Light the pilot wit a long fireplace match. After the pilot is lit, wait about half a minute and relese the knob,, the lp[ilot should stay lit.
Apr 03, 2010 | Water Heaters
Wont light
Is there a spark? or do you need a long match? The button usually just opens the pilot so it can be lit. If its not electronic.
Jun 19, 2009 | Pilot Pen Pilot Ignition Gas Water Heater,...
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Water Heaters Logo
196 people viewed this question
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
