Question about Frigidaire GLWS1649A Top Load Washer
Need to remove agitator on fridgidaire model GLWS1749FSO
  • Frigidaire Master
  • 19,396 Answers
Hi.
In this model the agitator (part 11 in diag. below) is held by one single bolt. All you have to do is removing the detergent dispenser and a cover (check diagram, it is part 66-67). After that reach the agitator, undo the bolt (nr 56 in diagram below) located on top of the agitator, and pull out the agitator.
Here the diagram, click on the picture to enlarge:
Here all parts and diagrams for your model.
Regards.
Ginko.
Posted on Nov 15, 2010
Fridgidaire stackable washer dryer model: fleb8200dso will not fill with water
You will need to replace the water inlet valve. Here is the part to order.
Here is the service manual to help you with the repair.
Nov 26, 2012 | Washing Machines
Need to remove agitator because clothing is caught underneath
To remove the agitator on most Maytag models, you remove the center post cap or softener dispenser on the agitator and locate the agitator bolt underneath. Remove the bolt and pull the entire agitator straight up. If this does not match your washer configuration, please post back with a model number so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | Washing Machines
Washer is leaking around bottom of the drum.
Yes, this does sound like the seal is bad. Unless you have replaced the bearing and seal in one of these bafore. It can be very dificult, without expierence. If not replaced correctly, it can still leak or can cause other problems.
Nov 14, 2008 | Washing Machines
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer keeps draining...
sounds as if your drain hose is too low. you need to have the hose higher than the water level in the tub. if the hose is below the water level the water will just pour right out
Nov 11, 2007 | Washing Machines
Frigidaire GLWS1649A Top Load Washer Logo
286 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
