Question about GrandTec Ultimate GWB-4000 Digital Media Streamer
My monitor has a bad image when connect GrandTec
All is working on my system with GrandTec Wireless. TV vision and audio is OK, but... Ever with the box powered or not my LCD monitor (on the PC) has a very bad image (disturbed like a ghost image), this problem is solved only when detach the GrandTec cable from the VGA adaptor on my PC.
I think that a disturbed signal is itrduced in my VGA signal by GrandTec box.
Why i can solve the problem and have a optimal vision on my PC monitor?
  • Anonymous Dec 18, 2008
    Same Problem. Very fuzzy when connected to my desktop monitor.
  • 689 Answers
Issue occurs due to interference and weak shielding.Using higher quality VGA cable will help also you may optimize display properties such as resolution and sync frequency
Posted on Jul 22, 2009
Sound ok white screen no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jul 28, 2014 | Sony KLV-37S400A 37 inch Multi-System HDTV...
How can i fix my hitachi ultravision it has green and double vision on top of screen
- Flickering screen
- Dim screen
- Slow start
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Can i connect my Sharp flatscreen tv to my wifi
Ron, in order to connect your TV to your home network, it will need an network interface. A network interface can be either a wired network jack on the TV itself, or a built in wireless capability (WiFi). You didn't provide the model number of your particular Sharp TV, so I can't tell you if your TV offers this connectivity or not.
Even if your TV offers wired or wireless connectivity, some TVs only allow network access to update firmware or to display "still" JPEG or GIF images; not to stream audio or video. The TV will need to have some sort of player to display or play video and / or audio files. Even then, if the TV is not fairly new enough, it may lack the support for newer file formats - such as .MKV, MPEG, etc. that are used for a large number of HD content.
You can get around this hurdle by connecting a newer computer to the TV. Purchase a wireless keyboard & mouse and connect the computer's video card to the TV so that it will appear as a monitor to the computer. Make sure your get a video card in the computer that will provide a digital video output - (HDMI, DVI, etc.) and a cable that can plug into one of the unused A/V inputs on the TV. If using a cable other then HDMI, you'll need to provide a cable between the computer's audio output and the TV's audio input. Use the computer's network interface to download or stream a program directly to your 55 inch "monitor".
I hope this helps - good luck!
Nov 13, 2011 | Sharp Televison & Video
I have a video splitter and I'm not getting anything on my monitors. The splitter says active and the monitor appears to recognise the splitter but doesn't show any images. Is there something...
an extended desktop
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
hope this helps
May 08, 2011 | GrandTec GVC-1000 (gvc1000) VGA Video...
Speakers are ok but headphone is not working
OK. Speaker works/headphones don't! Sultanrajia, what is refering to! Audio Amp, play-back record, computer, radio, TV, all communication equipment. what. It could be broken wire on the headphone jack plug or it could the headphone aren't working. Maybe some bad wire in the headphone cable, faulty plugs.
By the way, do have a Night Visison optic devise that it can take a look into the night. Also, how does the spearkers and headphone work with the Night Vision Optics? stewbison
Apr 08, 2011 | Optics
1) TV audio contnues after shutting off TV 2) No Images when correctly connecting to TV
Please provide waht system you're using, ie, Dell, HP, etc., with model number, what version of windows you are currently running and, Manufacturer(Sapphire, Vision tek) and model of your graphics card. It could be outdated drivers especially if your running Windows 7.
Mar 27, 2011 | ATI ALL-IN-WONDER 2006 EDITION, (256 MB)...
How to watch pc on a crt tv
You can watch pc to tv via wireless. Buy any pc to tv adapter.
Grandtec GWB-4000 Ultimate Wireless PC to TV System - 2.4 GHz, 4-Channels, S-Video, Composite, RGB, 1600x1200.
The Ultimate Wireless is the world's first truly
wireless PC-to-TV converter recommended for
professional presentations, computer gaming, and
internet browsing on TV.
Click here for more features;
Grandtec GWB-400
What's In The Box
* Ultimate Wireless converter/transmitter
* Ultimate Wireless receiver
* Composite + stereo audio cable
* Composite video cable
* S-video cable
* PC audio cable
* VGA pass-through cable
* 2 wallmount power supplies
* Battery Pack
* User's Manua
Jun 06, 2010 | Computers & Internet
I am only getting image in black and white on my TV. How do I get it to show in color?
Make sure that you have the little switch on the back of the Grandtec thingy to CVBS, not RGB or YCbCr - it's a three way switch - I didnt spot that at first...
Jan 29, 2010 | GrandTec USA PC-to-Component Video...
Cannot get any sound from Yamada Model L-151 (Type L5MTK6) when using it as a Monitor for Packard-Bell desktop running on Vista. Works OK as a TV. Tried "Line-in" & Red/white/yellow inputs without...
Run a 3.5 mm stereo plug out of your soundcard (line out jack, not speaker out) that has red and white rca plugs on other end. Plug red and white rca plugs into your Yamahas audio in plugs. I'm not sure exactly what to set the tv on to get both sound and video though. Let me know...Tim
Nov 08, 2009 | Audio Players & Recorders
Just want to know were the cords go for the swann wireless camera into the wireless box and the tv not gettin a picture thanks
The yellow cable goes to your video in on the tv
The red rca cable goes to audio in on tv.
Select the video1 or 2 on tv to get picture.https://images-na.ssl-images-amazon.com/images/G/01/00/00/03/25/09/78/325097870.pdf
Oct 01, 2009 | Lorex LW1020 Color Wireless Remote...
GrandTec Ultimate GWB-4000 Digital Media Streamer Logo
93 people viewed this question
Top GrandTec Televison & Video Experts
Electro Med Services...
Are you a GrandTec Televison and Video Expert? Answer questions, earn points and help others
