Question about GE 24 in. GSD2000Z Built-in Dishwasher
Spray arm and tower do not work properly. - GE 24 in. GSD2000Z Built-in Dishwasher
  • GE Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Nov 15, 2010
Indesit di620 dishwasher not spraying water from arms
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff.
Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
Jun 26, 2011 | Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
Top water wand does not turn
Does the spray arm spin if you push it with a finger? If not, the plastic bearing is in trouble--pull down on the plastic pin under the lower center of the arm which should release the arm. Check the spray holes for plugging and any split seams between the two halves. Check the bearing area for any stray debris. If it doesn't spin because little water comes out of the bearing area, then the likely problem is either a plugged screen in the bottom area under the lower spray arm tower, or a plugged port on the bottom deck under the pump impeller parts. You will have to disassemble the entire lower tower assembly down to the deck to service this area--make notes as you remove parts so that it goes back together properly. Soak the large screen in hot water and white vinegar solution (50:50) to remove the white hard-water deposits. Check the lower spray arm for hole plugging and split seams as well. Our Maytag washer suffered the same problems and by changing detergent brands seem to have no further events. Hope this helps!
Oct 10, 2010 | Maytag Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
Dec 21, 2009 | Kenmore Dishwashers
LEFTOVERS ARE STILL BEING LEFT AFTER THE CYCLE IS DONE. I RINSE DISHES BEFORE HAND BUT THERE IS A BLACK DISCHARGE ON THE BOTTOM OF THE TUB, AND SOAP STILL LEFT IN DISPENSER.
clean detergent dispenser drain hose could be kinked,check pump it could be dirty,is the water hot enough and is the detergent new?to remove spray arm un screw spray tower also clean out spray arm there may be food particles in arm as well as tower,try this out try washing unit with out dishes sometime vinegar or c.l.r will take care of problem but let it soak and don't add detergent.thanks
Dec 01, 2009 | Kenmore 24 in. 16362 / 16364 / 16369...
Top sprayer not working
Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
Sep 21, 2009 | Dishwashers
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
GE 24 in. GSD2000Z Built-in Dishwasher Logo
88 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
