Question about Olympus Camedia C-765 Digital Camera
It powers on, but will not function in any shooting mode. Won't even turn off once powered on. The LCD is frozen blue. To power off, I have to remove the battery. Even after removing the battery and putting it back in, it continues to do the same.
  • 3,083 Answers
Make sure the battery connectors on the battery and inside the camera are clean (use a qtip and alcohol), and make sure the battery is fully charged.
If the unit is still malfunctioning, it will have to be opened up to be serviced. Take it by a repair shop to get an estimate- often, it's just better to go ahead and get a new camera, since the cost of repair can be substantial.
Good luck, and hope this helps.
Posted on Nov 15, 2010
Change from lcd moniter to view finder
Try this, in your manual at the bottom of pg. 229 that says, "If you turn off the power while the 'shooting settings display' screen is displayed, the same screen will be displayed when you turn on the power again. To avoid this, press the <INFO> button to turn off the display on the LCD monitor, then turn off the power switch."
The converse also applies. Get into the shooting settings display with the INFO button and power down. The display will come on when you power up again.
It also solved my problem of getting the mode selection button selections to show on the LCD when needed.
Jul 13, 2014 | Canon EOS 7D Digital Camera
Blue power light frozen, projector won't turn on
Page 47 has nothing to do with this problem! Thanks for wasting minutes of my life
Nov 28, 2012 | ViewSonic PJD6211 Projector
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My camera flashes lightnot working how can i fix it?
Jan 16, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
My sony grand wega kdf e55a20 power light keeps blinking red. what can the problem be?
Red is an indication signal for power connectivity. Recent devices have two power functionalities. Using the remote control would turn off the display of images to power saver mode. A red power light imiting diode display is indication that requiring display of images is achievable by pressing on the display mode button once more. NOTES; Powering on the device may be achieved with the same function buttons as shutting down the entire Device to least communicate with the power supply circuity from outlet sources. The device is in power off mode ready for repower on with the remote control. Requesting the TV to shut down completely would require to press on the TV button firmly until power cuicuit are disbabled completely. Refer to the TV user guide to ascertain fucntionaility modes usual during operations. Goodluck
Jan 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
Protron tv 3250 tv went off. only blue light blinks
Your TV has two poweroff functionalities. First power off button is on saver mode least displaying any transmitter programs. Using the remote control to power off the device achieves screen saver poweroff mode. Second manually pressing on the power button after power saver mode has been achieved with the remote control device should shut down the TV tube entirely. The blue light should not display in whihc instance. Howerever, a full power off mode is incapable of being controlled by the remote control device whenver poweron is required later. The TV power shut down button has to be pressed again to alow for current circulation once more. Powering off the TV with the button on the set requiries momentary duration waits whenever to achieve display of signals depending on the size of the TV, and how many pheriperal device connnections are attahced to it.
refer to the TV user manual for possible diagnostic to any persistant conditions.
Good luck
Jan 08, 2011 | Protron PLTV3250 32 in. LCD Television
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Camera is frozen
My camera is frozen and it won"t turn off in less
I take out the batters.
Aug 18, 2008 | Samsung Digimax S630 Digital Camera
Olympus Camedia C-765 Digital Camera Logo
29 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
