Question about Bosch SHU43C05 Stainless Steel Built-in Dishwasher
Bosh dishwasher SHU43C05UC won't finish the cycle. won't drain and keeps running for ever when gets to 1 min left.Hoses checked and not clogged. I was able to drain the water by doing the test run and punching the rinse and hold button .what is the problem?
  • 2 more comments
  • pascalevann Nov 15, 2010
    The cycle goes to the last minute and goes back to 40 min .never stops. is it the same problem . the one didn't display when I tested .
    Could you please send me a PDF copy of the Bosch service manual?
    pascalevann@msn.com
    Thanks
  • SANDI FOSTER Aug 25, 2013
    Having the same problem and would also like to know where to get a copy of the Bosch service/repair manual? Please contact me at 1slfoster@gmail.com Thanks
    By the way, mine is not under a recall as stated below as my machines Serial # is FD8612 00039
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description " won\'t finish the cycle. won\'t drain and keeps running for ever when gets to 1 min left.Hoses checked and not clogged. I was able to drain the water by doing the test run and punching the rinse and hold button"
I'd say the issue is most likely with the control...unfortunately. The "1" being displayed is actually an error code associated with a heating fault.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, and it does apply to yours....based on just the model number, but check the serial number. It applies to serial numbers betweenFD7905 - FD8505 The issue was directly related to the heating circuit (specifically the heat relay on the control) Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be contacting Bosch re: the recall or calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to Bosh dishwasher SHU43C05UC won't - f57273b.jpgheater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further. I would recommend you contact Bosch regarding this recall, perhaps the repair will be free...but I don't speak for them.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 15, 2010
  • Mark MacDonald
    Mark MacDonald Nov 15, 2010
    The error code will only be displayed in the wash cycle, whereas in the diagnostic cycle ( provided it is done correctly ) will display the number "2" for a heating fault.
    I would still inquire regarding your machine being part of the "recall" as it is possible this problem could manifest in the manner you've described, yes. The machine is simply continuing to attempt a heating cycle.
    You could still remove the control and visually inspect it or perform the test program again place the ammeter as described in my initial post, this will confirm or dismiss a heater circuit fault.
    Let me know how you make out or if indeed you need further assistance. If you'd like to post your email address I can send you a "pdf" copy of the Bosch service manual.
    Good luck.
    Regards,
    Macmarkus :)
I have a SHU66C05UC which decided to run for 4 hours before I noticed there was shut off problem. I tried Mark McDonald's fix. It worked like a charm and my wife thinks I'm a genius. It took awhile to figure out how to get the board out. The dishwasher apparently is too old for Bosch to have a repair video about this model so I had to use some brain power to get the board out. Basically you have to take the whole front control panel completey out. The newer versions of the control board assembly just pop out from the back of the control panel after you remove the screws holding the front and back of the door together. I quickly found the burned up solder joint on the board and soldered the connection again. Anyway the job took about an an hour and a half. If you know how to solder electronics, this is an easy fix compared to a $325.00 replacement board from Bosch plus labor. Hint: Take a photo of the wire connections. It stops the "Did I do this right?" voice in your head.
TAP
Posted on Jun 29, 2015
How I get to the drain pump to check if blocked on Bosh Logixx Variodrawer dishwasher please.
Pull the inlet hose off the drain pump to check for clogs. If this goes into a garbage disposal back flush the pump with a pressurized water source will also work. This means removing the unit from the house of course. Do you hear the drain pump running after a cycle completes?
Jan 27, 2017 | Dishwashers
My Bosch dishwasher Model #SHX4APO5UC/06 wont finish the cycle and it wont drain. We have checked hoses and they are not clogged. Is it something with the control panel?
Check your motherboard for burnt contacts. Easy to remove in the door. If you able resolder and give it a try. Cheaper then a new mother board.
Aug 11, 2014 | Bosch Dishwashers
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Dish washer does not drain after final cycle
1 Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes. 2 Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain. 3 Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher. 4 Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose. 5 Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket. 6 Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Dec 11, 2010 | Frigidaire Professional Series 24 in....
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
4,827 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
