Question about Morphy Richards 42939 Iron
We got 42303 iron and use filtered water but we still get bits of scale coming out of the base
  • 3,083 Answers
I would suggest using distilled water, since something in the filtered water is producing the scale. If you switch to distilled, that should eliminate the scale.
Good luck, and hope this helps.
Posted on Nov 15, 2010
Testimonial: "thanks"
The iron heats up and the steam pressures up but wont come out. checked the holes and a wee bit of steam comes out once in a while
Sounds like something is clogged with corrosion or scale.
Most small appliance are not cost effective to repair. Suggest buy a new one and instead use distilled water.
Mar 21, 2018 | Irons
Why does water leak out of bottom of iron base unit when ironing .could it be the filter unit ?
Probably not the filter.
If it is a new iron and the drops of water are excessive I would suspect it is faulty.
If the iron is well-used I would suspect it has a scale problem where localised scale build up is preventing some of the water from closely contacting the heated metal and turning to steam. This could be particularly true if you live in a hard water area.
Steam irons originally soon caused problems unless distilled or de-ionised water was used. It is reckoned modern irons can use tap water but hard water can still cause trouble.
A descaler additive might help but I haven't had good results in the past...
Oct 19, 2015 | Irons
Steam stays on all the time
the valve is jammed
you live in england
so... take a calgon tab
and make up some boiling water
add the boiling water to fill the iron half way
now make up a paste with the calgon tab {a bit of like 1/8th}
add this paste to the water chanel of the iron
and then using a fresh boiling water
water it in
to fill the iron
let it sit for two mins
then exercise the valves for steam and water
and tip the iron front and back
let it sit a further 2 mins
NOW
plug in the iron and set it cotton number 1 {40deg usually}
let it sit and hiss
and steam it thru again exercise the valves
youll also need to make sure the holes on the base of it are clear
you can also leave the botton of the iron in a small tray of a calgon tab
this disolves all the lime scale and will bring perhaps
a sad iron or etc back to life again
after a good rinse thru reuse this treatment every few months
hey i live in glasgow so unlike the limes our water is pure gold
no lime ...
Jun 04, 2015 | Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
We have a GC8420 steam iron. The steam is regularly discoloured, first a pink, chalky stain - very difficult to get out of fabrics - and today a lot of dark brown/black water coming out. We do empty out...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Jul 14, 2011 | Philips Irons
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
heatman101
Mar 23, 2011 | Tefal Avantis 90 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
While steaming clothing, a white flaky residue is being left on the clothing. Sole plate is clean. Residue seems to be coming from steam vents. What do I do to continue using this great iron? Evelyn Roll
Are you in a hard water or soft water area, maybe you could try using filtered water in your iron. To clear out the scale from the jets try adding a little white vinegar to the water and steaming it through, or a little "Calgon" diluted in water. Then perform a test iron on some dark fabric untill the scale has been removed.
Aug 02, 2010 | Rowenta DX6700 Iron
Steam comes out of the base system reducing the amount of steam that now comes out of the iron. The filter has been changed, could it be block with scale.
Yes it could. Try using CLR, Lime Away, both are Calcium, Lime, and Rust removers. They attack and disolve all 3 types of build ups almost instantly. You can buy eithere at most supermarkets, hardware stores. Use it on your shower heads too, it will improve water flow, Follow instructions to the letter,
May 16, 2010 | Morphy Richards Jet Stream 42271 Iron
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 | Irons
Morphy Richards 42939 Iron Logo
Top Morphy Richards Irons Experts
Mack Baxter
ray gallant
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
