Question about ASUS M3A78-CM AMD 780V AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Athlon... Motherboard
Yesterday I shut off my computer normally (start, shutdown) and when I went to turn it on a couple hours later, the computer powers up and everything sounds normal, but nothing is displayed on the monitor. I have tried switching the monitor and still nothing happens. The internal speaker no longer beeps (and I have checked the internal speaker). I have tried removing the CMOS battery for a couple hours to possibly reset the bios but still nothing comes up. If anyone has any suggestions I would appreciate it! Computer Specs: ASUS M3A78-CM motherboard, AMD Phenom 9600 CPU, Kingston HyperX 4GB (2 x 2GB) RAM, ASUS EAH4670/DI/512M/A Radeon HD 4670 GPU, OCZ GameXStream OCZ700GXSSLI 700W ATX12V PSU.
  • Corey Beebe Nov 15, 2010
    Thanks. After removing the RAM and replacing it, the computer booted up just fine
  • ASUS Master
  • 13,433 Answers
Hello
If you know that the display is working, (you've tested it on another machine or similar) Then the issue is with the machine obviously.
Lets begin by removing all the RAM from the machine, (Unplug first of course, and press the power button so that any remaining power is released)
After you have removed all the ram from the machine, plug it back in and power on, it should BEEP.
Turn off the machine after you have gotten tired of beeping (just turning it on and hearing the beep is enought, if you don't hear a beep there might be a more serious problem, but more on that later)
Plug in one of the Ram modules. And power on again. you should get picture now as long as the machine beeped before, if it doesn't try the other module.
By now you should be getting picture out of the machine, if not, the problem is possibly the video card, cpu or mainboard.
Unplug all the extra devices on the machine, only leave connected, Powersupply, mainboard, cpu, ram, video. disconnect all the cables going to dvd drives etc.
Try turning on again, if you still don't get anything, remove the video card, if possible try another card, power on without the card and turn off again, plug in the card again.
You should have gotten the machine working by now, by trying another video card, if not, the problem is either the cpu or the mainboard.
There is a Clear CMOS jumper near the mainboard battery, removing the battery is not a good way of reseting the bios, best way is to use the jumper on the board.
Posted on Nov 15, 2010
  • Ekse Nov 15, 2010
    Run memtest program, since you have 4GB of ram you need to start 2 instances of the program, first program set the memory to be tested 2048MB and the 2nd one leave it on: test all free ram.
    Let them run for a hour to confirm that your RAM is working properly.
    If any kind of error messages start coming up you have faulty ram, Kingston should have lifetime warranty if I remember right.
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Stratus wont start
Could be crankshaft sensor.
Apr 27, 2013 | 2004 Dodge Stratus
I have a M9601 alarm and M99 immobiliser fitted to a mk5 xr3i,everything was fine until yesterday when the car was started first thing in the morning as normal but i had to go back indoors so meant turning...
Hi
if the battery is not much good then you will get issues like this also being a ford I would check the earth connection from the car battery to the car body, the main feed. also there is another o the gearbox and another that runs to the altenator, these are all common poor earth problems. ensure they have a good conatct.
Secondly have you checked the fuel relay is not loose or maybe on it's way out, this again is not unusual, if the relay fails then it has an electro magnet inside, poor powr from the battery will make it stick either open or closed like a light switch kinda, you should here it ticking at the fuse box when the key is turned, also immobilisers often use this part of the cars wiring to stop fuel coming to the engine as a security measure. Maybe thats the issue the immobiliser shutting the relay down.
I would certainly check that first as its super simp,e to replace.
Regards
Dan
p.s if you need more info get back to me
Jan 08, 2011 | 1993 Ford Escort 4 Door
THE ACER MONITOR AL1711 BLINKING IN DIFFERENT COLOURS AFTER THE COMPUTER IS SHUTDOWN - TO STOP IT I HAVE TO REMOVE THE POWER TO THE MONITOR OR BEFORE SHUTTING DOWN I HAVE TO PUT THE POWER OFF FROM THE...
I just had this problem at work and what I did was I powered up the computer and went into the menu. I went to the 2nd to last button and selected the reset. It's working perfectly now. I do not know if it will last but it's easy and free.
Jan 23, 2009 | Acer AL1711 17" LCD Monitor
Car won't start
test/replace the alternator.also be sure all connections are tight at battery...ground side other end of battery especially..good luck
Dec 12, 2008 | 2003 Kia Rio
Computer shutting down
do you get a blue screen when it shuts off? or... does the monitor just turn off, or does the computer tower and everything turn off?
If everything turns off,(like a normal shutdown) try checking your power options in the control panel, to make sure there aren't some power saving settings that are causing it.
If its a blue screen type issue, then there may be a hardware problem that is causing the computer to shutdown to avoid further damage to the system.
Jun 27, 2008 | Acer Aspire T120 PC Desktop
ASUS M3A78-CM AMD 780V AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Athlon... Motherboard Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
