Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Touchscreen quit the touch screen has stopped working and it is VERY slow on any response including powering on and startup
    Problem Solver:
  • 6 Answers
My phone was doing the same thing and they gave me 3 new phones and when my forth phone broke I called alltel and they told me to hold the two soft keys (red and green button) while hitting the reset button on the bottom of the phone with ur stylus. U r gonna lose all ur information u have saved to ur phone but if the screen is not working then the information in it is useless anyways.
Posted on Jul 15, 2008
I have an ASUS laptop with Windows 10 and my touchscreen has stopped working. I reloaded windows as I found the HDI driver for the touchscreen was ghosted-no luck. Still no driver for the touchscreen
device manager does not uninstall programs
you have to go to control panel select programs , select uninstall and then highlight program to be uninstalled the click on uninstall.
try to find the touch screen and then click on properties , find the driver tab and click on upgrade driver .
you could always go google and type in --user manual for asus touchscreen laptop--- and down load the pdf version
what you want may be included in the manual
Dec 29, 2016 | ASUS Computers & Internet
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Touchscreen not working.
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
Nov 24, 2013 | Acer Aspire Z5600 PC Desktop
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Touch screen problem
If you're still having touch-screen problems with your Tipo, you might need the screen calibration patch.
Download this file:
http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
The file is the official screen calibration patch from Sony for issues with the touchscreen of the 2012 range phones (I'm 100% sure it works on: Tipo, Tipo Dual, Miro and Xperia J)
Dec 20, 2012 | Sony ST21i Xperia Tipo Black
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Cell Phones
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
