Question about Dryers
Sqeeking while running - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Nov 15, 2010
Mustang breaks sqeeking
Depending on what type of pads you are using and/or how old the brakes are it can be several different things. If your brakes are worn out...it could be the squeeler touching the rotor. If not if could be that your using a semi metalic pad which can cause sqeeking. Or it could be that your rotors are glazed over from overheating. If this is the case they may need to be "turned" by your local shop
Jan 30, 2013 | Cars & Trucks
On 2000 dodge durango alot of sqeeking on fron t drivers side when you drive
Check your suspension including lower A frame where it attaches to the wheel. Does it squeek more at low speed?
Sep 07, 2012 | Dodge Durango Cars & Trucks
When I start the car there's a loud sqeeking noise that goes away after 1 minute 2003 es 330
if it was mine, I would buy some "fan belt dressing spray" and spray my fan belts or have them adjusted. first spray them once, if sound stops a few days, have the tension adjusted. if spray does not work the first time, this is not the problem.
Apr 16, 2012 | 2004 Lexus ES 330
2002 gmc truck water pump making noise how to stop noise
Gday mate, geoff here, could be the belt mate, try a bit wd40 / rp7 / crc, on the belt just a quick squirt or rub some soap on the V of the belt ,if noise persists could be the pump itself worn, does it have any lateral or dynamic play when wiggled, while engine off of course, hope this helps , geoff.
Feb 11, 2012 | GMC Sierra 1500 Cars & Trucks
Dryer squeaks while running. What could the
brand helps but sqeeking is normally a idler pully,,,glide,,or drum wheel/support www.myabcspace.com/washerwizzards
May 15, 2010 | Whirlpool LER5636P Electric Dryer
In reverse 2002 Maxima makes a sqeeking sound.
IF THIS noise IS COMING FROM a WHEEL IT IS BRAKE PADS OR SHOES, If it is Coming from the TRANSMISSION It NEEDS to GO to A TRANS SHOP or Dealership as it would be an INTERNAL Fault.
Hope this Points you to the Problem !
Oct 02, 2009 | 2008 Nissan Versa
Sqeeking noise while running
Squeaking usually caused by belt idler pulley or drum support roller.
Model number of unit is always helpful when posting.
Aug 22, 2009 | Amana Dryers
Sqeeking noise.
sounds like u need a new belt may be dry rotted or just worn but also look at your belt pullies
Jul 12, 2009 | 2000 Nissan Pathfinder
Makes a sqeeking noise while turning or on bumps
Suspension problem like a rubber bushing. Try recreating it, have some one push up and down on the front fenders one at a time, asuming the noise comes from the front. Try and spot where is coming from, if the part looks good spray it with lubricant not penetrating oil. Is best to replace what ever is making the noise.
May 11, 2009 | 2006 Chevrolet Equinox
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
