I have a LG television (32LX2R) and it is stuck on standby, just can't get it to turn on. I have tried turning it off at the mains ans leaving it for a while which has worked in the past but now it just won't turn on at all. Any ideas?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
All the internal parts you need to repair this model are available here, contact them if you're unsure what the faulty component is:
Search results for 32LX2R
Posted on Jan 02, 2016
    Novelist:
  • 144 Answers
Have you tried unplugging it for a few minutes and them trying again? Doesn't solve the underlying issue, but may reset the unit to work again.
Posted on Nov 15, 2010
  • 1 more comment
  • ben_stamp Nov 15, 2010
    as stated i have tried this before but it no longer works by unplugging it. Whats the next step?
  • William Robinson
    William Robinson Nov 16, 2010
    Sorry for the confusion. You stated you turned it off at the mains which could be interpreted as turning off the main switch, not fully taking the power away from the unit (hence unplugging it). As I stated that was the first step. Second step is to see if the power on at the tv works (and the remote). You can also try and unplugging it once more. Press and hold the power on button for 10-15 seconds (to discharge the capacitor) and then plug it back in. From there you are looking at a control board problem which with todays sets means changing out the board instead of trying to fix the individual parts. I don't know how brave you are or your skill set, but can talk you through opening the unit up and looking at specific areas as well. Let me know how you make out and please write back with any questions.
  • godike Feb 18, 2011
    hi there. I have the same problem as ben does. The tv is always in standby mode and cannot wake up. I already tried to take the power unit out, checked it out if everything is ok and so on. Is there any advice you can give to bring this tv to life? I have also tried to override the main unit and to start the 12V part on the power unit, it worked and the blue led at the bottom lighted up but the tv did not wake up. So.. any ideas for that? thank you in advance.
37LC2D LG PLASMA TV Solid red light is on no sound picture
The unit is stuck in standby. Have you tried turning it on manually on the set or changing the batteries in the remote. Does the light flash when you try to turn it on?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG 37LC2D Television
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
LG plasma just turned off for no reason, try to turn back on , but blue light(on) flashes for 2 seconds, then turns red(standby)
Try unplug,replug for reset that all could do,same prob.must change tha Main backlight Vivdeo board.
Nov 17, 2009 | LG 50PG20 50 in. Plasma HDTV
LG 32LX2R TV - AV2 in B&W
factory reset for the PS3.
turn the power off on the PS3 what I want you to do now is turn the power back on whilest holding the button down for approx 5 seconds this should then bleep. Thats it reset.
Hope this helps you out.
Little Dish Fitter.
Oct 07, 2009 | LG 32LX1 32 in. HD-Ready LCD Television
Can not get tv to turn on
It's normally a power failure/surge on the main board. Most common with LG tv's of this type. Samsung tv's of this type don't actually turn off, they only go on standby, which is why you can turn the Blue Eye off in the menu. One solution to try (if you haven't already), is to disconnect it from the mains (this is also the only way of actually turning the tv off), leave it for 24 hours, and try again.
Nov 28, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Having problems with my new HD TV (LG 32LX2R)
Hello, please call the dealer ASAP. This should be an in warranty case. Best regards, Arpi
Jun 24, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Televison & Video Logo
537 people viewed this question
Top Televison & Video Experts
