Question about AudioBahn A2300HCT Car Audio Amplifier
2300HCT Audiobahn Amp
Hi i was just using the amp like it should be used powering two 10" solobaric's and it just stopped powering the subs and my volt gauge in my car just dropped everytime the amp was on. Like the amp was using a load more then it should. So i benched tested the amp and it can be on and not drain the power drastically and right when i plug the rca's in and then the subs require the amp to push them then it uses a lot of power. I don't know what it is. So can someone please direct me in the right direction to a place where i can get it fixed, the electronic places around where i live only deal with kicker and rockford fosgate. Please email me at hansonz1@hotmail.com with some information, Thanks.
  • 20 Answers
It's probably a short someplace on the Main Board. I would suggest calling Audiobahn for a certified repair specialist around you.
Posted on Jun 19, 2008
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Hi, i have jbl 1201.1 running 2 audiobahn aw1200v subs, i used to have 2 jl audios but the amp blew them, when i turn up to about 32 volume the subs cut out, they come on and off, amp doesnt go into...
well first off the cap should be reading 14.00 volts not 12 but check on ur settings maybe its to high if that dont work then ur amp or amps is way to powerfull for those sub or theres not enough watts from the amp to the sub causeing the amps to under power the subs but let me no if u got it im all wayz here to help
Apr 04, 2008 | Car Audio & Video
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Jl sub not powering on
ok try your sub on another amp is first find out if that works or not if it works then there's a good chance you amp is knackered
Feb 22, 2007 | Jl Audio 10W3v2 Car Subwoofer
AudioBahn A2300HCT Car Audio Amplifier Logo
91 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
