Question about Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch
Lost power and need to reset the timer. - Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
http://waterheatertimer.org/Aube-timers.html
If you have different timer, add a comment
Posted on Nov 16, 2010
Who have purchased 2 (actually 3 but the other one was a different kind) utilitech 0050024 outdoor timers and both keep resetting to midnight on monday as of the power has gone out. All programmed info is...
Sometimes people get batches of bad timers.
However this timer does not show a program carryover, and does not appear to have battery for carryover. Although many new timer have a capacitor backup, it is unclear if the Utilitec offers this feature.
http://waterheatertimer.org/pdf/Utilitec-0050024-tower-stake-manual.pdf
Use reset button to clear memories, and then reprogram.
This timer has 2 modes: programmable or photocell
As a general rule, these timers come with 1 year limited warranty, but unclear who backs Utilitec warranty.
Buy two new timers from different Lowes store, and return defect in new package.
Jun 12, 2013 | Hardware & Accessories
Every time I have a power failure, the timer stops working and I have to reset all the programs. I thought there is a battery built in to protect the programs during power failure. Why it is not working in...
Timer is not identified.
Copy following link to help identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Most modern digital timers have programming back-up that lasts indefinitely in memory until timer is reset.
However current time is sometimes lost with low battery or power outage.
In some timers there is rechargeable battery that protects all settings. This battery is non-replaceable, and can last a few years or more-less.
Since the market is changing rapidly, who knows what remarkable innovation will lessen quality, causing shorter lifespan of product.
Most timers have limited 1 year warranty against defects in workmanship.
Nov 24, 2012 | Hardware & Accessories
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
The timer blinked low battery, we replaced the battery and now it needs to be reprogrammed but we have lost the manual. How do we reprogram it?
You posted under ST01C timer.
Open following page to read ez steps and download manual.
Unless you reset the timer, then programming will still be saved forever.
Even if battery was dead, programming remains saved inside timer until timer is reset or stops functioning.
So all you need to do is set current time.
If the timer will not work, then reset timer.
Mar 27, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Bulb comes on, turns off immediately on timer-installed switch
there could be a few reasons for this,
1. the timer could have been damaged during a power surge, = unusable and needs replacement
2. The program set to switch on and off was lost, and needs to be reset, try to operate the reset button, and setting the parameters again., If this is the cace, make sure the backup battery is still ok
Oct 24, 2009 | Kitchen Appliances - Others
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch  Logo
312 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
