Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Flash drive not work at all and indicate buld is not flashing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
When you plug the flash drive into the usb did it shows new hardware found like that in the task manager?
Jyo
Posted on Jun 19, 2008
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Clover CDR 4170
u need at least a 4gb, then system search, enter the time and date u want to back up press enter, once u have it on screen put flash drive in usb, then hit the back up button.
Jan 17, 2009 | Clover Corporation CDR-4070 Video Recorder
Drivers side rear turn signal and brake light not working
I've noticed the same problem with my 2001 Ford Exployer Sport Trac. When my girlfriend drives my truck she raises the steering column, and when I'm driving, I lower the column. I noticed when I was driving recently the left front turn signal kept flashing quickly, thought it was the bulb, but changed and still happening. Today I took apart the steering column cover and noticed the wiring for the turn signals and hazards were loose. To fix this problem I pulled the wires out of column more as to not stress the connection. So far this has fixed the problem.
Dec 14, 2008 | 2001 Ford Explorer Sport Trac
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Indicator flashing 2 fast at off side all bulds illuminating
double check all bulbs are illuminationg (including the side repeaters / wing mirror repeaters) and check the fuses
Oct 13, 2008 | Land Rover Discovery Cars & Trucks
Flash brive wont work
The problem wasn't my flash drive, it was the USB cable that ran from my printer to my hard drive. All I had to do was change the location of the USB cable to another location and the flash drive worked after that with no problems.
Jul 13, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flashing "F" on front of drive slot
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
Aug 29, 2007 | StorCase 9 Bays Data Silo DS550 Storage...
Broken flashbuld on sony cyber-shot model dsc p-10
In short - no Repair as an economic proposition. If you don't need the flash live without it. If you need flash - buy the next camera
Jul 18, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
64 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
