Question about Zanussi Dishwashers
My zanussi zdf131 has not caused any problems during the last year or so since i purcheased it, but now all the dishes etc come out with a "bloom" of white over everything. I've checked all filters etc, run several cleaning programmes but I've now noticed that the salt level does not seem to be going down. I check it every week & refil but this time the salt has been in the reservoir for several weeks & doesn't seem to have changed - could this cause the problem & if so why is the salt level not going down?
  • 3 Answers
SOURCE: atp3 wont power up why?
There is an internal fuse in the Altec Lansing Speakers ..BUT BE CERTAIN TO DISCONNECT THE POWER LEAD BEFORE MAKING THE FOLLOWING REPAIR.AS IT CAN BE DEADLY!!!
If you remove the larger screws from the back of the unit then remove the top section with the circuit board attached. Next remove the screws attached to the bass speaker as you will need to remove the speaker to replace the fuse.
Once the speaker screws are removed there is a little recessed slot in the timber for you to put two fingers in to lift the speaker out. It may offer a little resistence as there is a dab of glue holding the cables into the cabinet next to the speaker.
Once you have the speaker removed double check that you have disconnected the correct power lead to your ATP3.. The fuse is easily visible so pull it out and check with meters to see that it has not blown.
Alternatively take a 9 volt battery ( the type with both terminals at the top of the battery). Place your tongue over both terminals to verify it has a charge (you will feel a slight tingle on your . tongue).
Next place one end of the removed fuse on one of the terminals.. now short curcuit the other end with your tongue touching both the unconnected end of the fuse to the other unconnected terminal ... this should complete a circuit and give you a slight tingle.. ( it wont hurt you!) If there is no tingle the battery is either flat or you have a blown fuse.
If the fuse is OK, then chances are you have a faulty pin connector - your "right out" connector. Sometimes these get bumbed with the feet if you have it on the floor and they can lose the contact needed to switch your unit on.
You then need to either re-solder the pin out socket on the circuit board or repair the cable that plugs into it.
If someone has worked out how to solder a jumper lead on the board at the pinouts you may be able to have the power on permanently and then use the wall switch to turn it off and on.
Posted on Apr 13, 2008
SOURCE: Zanussi DE 6554 Dishwasher
Wash the dishes by hand and view them again 1 hour later. If the dishes are still cloudy it's too late you have been running in hard water for years and etched the dishes. Salt only regenerates the Xeolite beads inside the DW. They collect minerals until they can no longer hold more, then the DW washes the minerals off the beads with the salt. Check if the DW is set correctly to the appropriate water hardness of your town. READ THE OWNERS MANUAL. PS> 1. You can't use regular salt. 2. Is the salt dry? Salt must be added into water so it creates solution (brine).
Posted on Jun 04, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Posted on Jun 17, 2008
  • 25 Answers
SOURCE: 2003 Honda Accord Check Engine / Maintenaice Requeried
If you brought your car to Honda for service, they probably forgot to reset the maintenance reminder. If you took it to another shop, they probably did not know how to reset it. Anyway, the reset procedure is:
Put your key in the ignition
Turn the key to the II position for a couple of seconds
Then turn the key to the off position
Now push and hold in the odometer reset button
While still holding the odometer reset button, turn the key back to the II position
Hold for I think 10 seconds or so and your maintenance reminder light should reset it self.
Posted on Jun 20, 2008
SOURCE: My check engine light comes
i am buying a 1989 buick lesabre for $800 and just put $400 down yesterday and $400 next week too and i was driving the guy home to his ranch.he is a teacher i had last year and i gave him a ride back to his ranch and then i drove home.no problems there.i got home and was leaving to go show the car to my sister-in-law and i was at the bottom of my drive way and the car just dies.my dad gets it started and puts the car in drive and the car died again in the middle of the road which wae live on a busy road so i pushed it into the stores parking lot.he got it to start again and drove it to the gas station by our house and filled it up.then it started reight up and ran decent.well,lately,i had it checked out,found out that the front brake line has started to crack and that the brake pads are starting to wear down.the car has 119,685 miles or somewhere around that.the check engine light has been coming on and the car still runs though but then after a little while,the light for the check engine soon light goes off and the car remains to run.i was wondering on what could cause this to happen.thanks.
Posted on Oct 12, 2008
We have a Zanussi that has been fine for 2 years but the last week it has turned a powdery white inside and on the door with all the dishes becoming chalky. There is rinse aid and salt. Hope you can help
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Jul 15, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
Rotors not turning during operation
Confusing..You say in one line Rotors not turning during operation. next line says
The top & bottom blades are able to move freely?
Il try & help anyway.1st the water level may not be high enough to load the the wash motor & spray water.2nd the dishes or cutlery may be hitting the arms.
May 30, 2010 | Zanussi 24 in. ZD686 Built-in Dishwasher
Smelly dishes
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Aug 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi DE540X Dishwasher
I have the same problem. First fault was caused by poor workmanship on the assembly of the PCB. There is a relay (the largest component on the board) which was badly soldered and caused some arcing resulting in solder splattered around the plastic casing and a lost electrical connection. This relay switches the mains voltage on to the heater i.e. 240V around 8.5A for a 2kW heater. (26 ohms suggests a 2215W heater for the case mentioned). Re-soldering this connection solved the problem for about a year. Now the dishwasher is showing the same problem. I have tested the relay and it is operational, but does not seem to be turning on during a wash cycle. A new board costs around £100. Zanussi will not even provide the technical details to allow a home fix. I will post my finding if I get to the bottom of this problem. It may be to do with electrical temperature sensor. My hunch is the controlling PCB is cheaply made and will not last a reasonable lifetime. A dishwasher is in itself a very simple piece of equipment with only a few valves, a pump and a heater so should not give problems in its first five years of life subject to normal usage. I will not consider purchasing any Zanussi appliances in the future.
Mar 24, 2007 | Zanussi 24 in. DA6153 Free-standing...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
66 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
