Question about Gateway FPD2275W LCD Monitor
My SVA monitor 5 blacks out after 5 seconds
When I turn on my PC, I can see the windows logo and everything clearly. Then about 5 seconds the monitor blacks out. If I hit F8 during bootup, the monitor stays on and shows all the normal setup features. This tells me the monitor is working. I suspect something had been done to the display setup without my knowledge. What would you suggest? How do I restore the original display setup? Thanks!!!
  • 558 Answers
Use f 8 to go to safe mode then set the resolution at the very least liek 8 bits or whatever the lower=st is and save it then restart in normal mode and then play with the resolution in display settings to get to the ma your video card will support.
Posted on Jun 19, 2008
Sva monitor model 2400w-bd. have two set up and one keeps going to a black screen after a few min of being on. turn power off and turn back on and screen returns. this is a constant and very annoying...
Your monitor is suffering an overheat condition due to the switcher internally working too hard and overheating, shutting down the switching supply. Replace the electrolytic caps on the board with new low esr ones and you should see this problem go away.
Sep 25, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SVA 15" FLAT SCREEN MONITOR
maybe you have defective parts in oscillation circuit! in hotside of the power supply! or maybe you have loosed contact at the main board!
Oct 28, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
When I boot up my PC the monitor will blink the windows logo and sign on for a second then go black....if I turn off the power button on the monitor and pust it back in the monitor will again blink the...
Could be the resolution too high for the monitor.
Try to press "F8" during the "Starting Windows" message, then select the safe mode or VGA mode.
After logging in check the resolution and if needed reduce it.
Could be also a video driver problem.
Use the same "F8" trick to get to the safe mode and reinstall the video driver.
I hope this will give you some ideas
Apr 05, 2011 | AOC LM729 17" LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Sva 15" flat screen monitor
You have a bad power supply capacitor or two. Very common. Not worth fixing, these are free on craigslist *replacement monitors like this
Oct 27, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
