Question about Maytag Kitchen Ranges
My oven lower burner does not light up, but the broiler burner does
  • Maytag Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 15, 2010
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
My broiler works but oven is not heating. Is this an ignitor problem?
That could be a good analysis---
Here is an observation you can make thru the oven door:
When you turn the oven on to BROIL-- do you see the bright glow of the ignitor?
(It is almost like a light bulb was in there-- buy the burner!)
When you start the oven (on BAKE) setting-- do you see a similar bright glowing light?
(Tho down lower, near the Lower Over Burner)
If you see the bright light-- then the ignitor is apparently heating up--
If not-- then, YES-- you are likely right--
Ignitors are fairly common failure items-- and they can obviously stop the burner from lighting-
Make sense?
Let us know if we can help further.
Mack B
Jan 15, 2011 | GE Ovens
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
63 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
