Question about Sony DCR-SR40E Mini DV Digital Camcorder
I can't hear any sound during the camcorder playback mood, but there is no problem to hear while connection on TV.
  • 10,594 Answers
It seems internal/ inbuilt little speaker is bad that is why you do not get sound in camcorder itself during playback. Please check internal speaker and replace it to get sound.
Let me know exact model number written on bottom of camcorder to provide you speaker part number , if required OR take it in local camera repair shop for speaker replacement.
Thanks.
Posted on Nov 15, 2010
How do you turn the volume up?
Do you mean playback on the camcorder, or playback via a TV or PC ? If on the camcorder, there may be a menu setting for this - check the manual. If TV or PC, use the volume control on that.
Alternatively, there may be a menu setting to permit you to record at a higher volume. Be careful if you choose this, as background noise will also increase in volume.
Mar 10, 2016 | Canon Video Cameras
I have a Ge camcorder 8mm model Cg814. When powered on and placed in the edit/playback mode for reviewing, I can hear the sound, but there is no picture in the viewfinder. There is also no picture on the...
It sounds like it could be: (1) Video track on the tape might be messed up. Or (2) The heads on the camera may be dirty. Or, (3) It may be dirty battery connection. (Most likely, it's dirty heads.)
Solutions: (1) Try playback with a different tape that you know is good. Still nothing?? (2) Run a head cleaner specific to your camera, for about 20 seconds. Remove head cleaner and wait 10 to 15 minutes. Put tape back in and try playback again. This will probably solve it.
Another thing to try.. (3) Turn camera OFF. Remove the battery, wipe off the connectors on both the battery and the camera with a clean cloth. Return battery to the camera.Try playback again.
If these steps don't solve the playback problem, you will probably need a camera repair person.
May 16, 2011 | Video Cameras
No sound during Playback
we have the same problem..mine is sony dcr-sr200
Feb 05, 2010 | JVC Everio GZ-MG37 Camcorder
No audio during playback
On my handycam you have to hit the Volume + button while playing back. Everytime you playback it starts volume at zero and you have to volume up to hear anytime you playback.
Dec 24, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Audio volume
Unfortunately, connecting an external mic is not an option that was engineered into this model camcorder. Likewise the speaker and small amplifier for audio playback is simply what it is. You should be able to adequately hear normally recorded levels. If not, maybe there is a problem with the internal condensor mics or the playback speaker. If you are unable to obtain a resonable level using A/V cables to a TV, then something could be wrong. I have not seen problems with this model regarding sound, but anything can happen. Good luck, ms
Aug 30, 2007 | JVC Cybercam GR-DVL520A Mini DV Digital...
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-HC36 wont playback on TV
if the sound is coming out on tv then the video cable has to be replaced. (You did not tell if the sound is coming out on tv)
Jun 25, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
No sound during playback
you need to check whether sound is ok tru av out leads ,or is it problem with no sound while trying to play back in camera as have seen a few of these with internal speakers going faulty.if you try it tru av leads you should have sound if this is the case
May 09, 2007 | Samsung SC-L906 Camcorder
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony DCR-SR40E Mini DV Digital Camcorder Logo
384 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
