Question about Polyview S17E 17" LCD Flat Panel Monitor
Polyview Monitor Black screen
Power connected to monitor, indictor light on but black screen. Any ideas?
  • info737 Dec 02, 2008
    The power light and some time the monitor flashes
  • 558 Answers
Blown capacitors open it up and take a look
Posted on Jun 19, 2008
BLACK SCREEN
Does it go black if you you use it as just one single monitor? If it does, you will need to open up to inspect the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 20, 2010 | Chi Mei Corporation Polyview V396 (Black,...
Polyview V17E monitor looses power at irregular times
Check your power saver settings
Start - Control Panel - Power
May 08, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Dec 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Black screen
Not enough information given! Do the monitor power light come on? Is the monitor making some type of noise? Can you feel satic on the face of the monitor
Nov 30, 2007 | KDS Avitron 195TF Monitor
Like most of these LCD monitors it is more than likely a PSU problem to do with the Electrolytic Capacitors, These in all probability will be faulty.. there are usually about 4 - 6 from 1000uF to 100uF replace ALL with same or better.
May 31, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview S17E 17" LCD Flat Panel Monitor Logo
119 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
