Question about Canon ES8400V Camcorder
I have not used my es8400 camcorder for three years and the battery only gets up to 6.88 volts do I need to by a new battery?
2 Suggested Answers
SOURCE: want to know how to record to a dvd
what do i need to do to hook up my es8400v to my computer
Posted on Jan 31, 2010
No lights new batteries on a Jazzy Select
Most batteries will go bad when then sit for two years. You will need to test the voltage at the joystick. A volt meter is required for this test. They are three holes in the end of the joystick. They are labeled 1-2-3. The probes of the volt meter most go in holes marked 1 and 2. The red probe goes in #1 and the black probe in #2. If the batteries are good you should get a voltage reading between 24 and 26volt dc. If you get less than 22volts dc the chair will not run and less than 18 the chair will not turn on.
Oct 07, 2015 | Select Health & Beauty
Will not start. battery seems to be ok. will start if you jump.
put a volt meter on the battery and if it reads below 13.5 volts the alternator is bad
Sep 07, 2010 | 2002 Toyota Highlander
Will not turn on with good battery.
Can you not detach the lead to the charger unit, and plug that directly to the camcorder, to see if its the actual camcorder at fault ?
Near the camcorders power socket, you should see a small picture telling you what power the cam uses - usually around 7 volts, centre positive connection jack plug, at around 900mAh. As long as you get the voltage close, and have enough amps behind it, it will still work safely.
Camcorders are rarely fussy about the exact voltage, but you should never go above 9 volts unless its needs more. Most take the internal power down to 5 volts inside anyway.
The batteries do have a tiny non-replaceable internal fuse, triggered by voltage spikes or overheating, and if that goes, it usually means buying a new battery :(
Batteries can go at any time from the very first second they are used. I've bought many, and had a few that didn't last 2 months from brand new. One high-end type lasted over 9 hours on its very first charge :) and then never worked again after that :(
Apr 03, 2010 | Canon ES8400V Camcorder
Camera acts dead. Hasn't been used for a long time. Will not turn on. anti-ground swithch is in start/stop mode. replaced 3 volt lithium battery. nothing operates. battery in or out, charger in or...
I need exact model number of your Sony camcorder to find out reason of no power up problem.
Please check charger output volts with multimeter as it should be equal to written on back of charger, approx 10V DC
Thanks.
Mar 27, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
Stalled at stop sign. Battery seemed dead. New battery bought apx 1 year. Got it home charged battery for 5 hrs. Bike barely started. turned off and not able to start. Obviously it could be battery but the...
Yes it can, Take it to AutoZone and they can test the alternator with there volt meter unless you have one, if it's a 12 volt it should at 700 rpms run 13.5 volts to 14.5 volts out put. All you have to do is connect to the volt meter to the battery leads + to + and - to - if it reads that then disconnect the batter post on one side and with the key off put meter on 12 volts dc put one lead from the teat meter to the battery post and one to the battery cable, if you get a reading then you could have a short or two three problems, and would have to look it up cause I don't remember, one could be a stuck brake light switch so Post here if you would like for information after Please rate this free answer if it helped you and thanks for using fix-ya.
Avid101
Aug 20, 2009 | 2002 Suzuki VS 800 Intruder
Want to know how to record to a dvd
Apr 03, 2009 | Canon ES8400V Camcorder
LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Aug 17, 2008 | Canon ES8400V Camcorder
Problem charging GR-DX77
check the charger output if it has an DC out voltage about 8.4 volts. If it does not have, your charger is effective.
Aug 07, 2007 | JVC Handycam GR-DX77 Mini DV Digital...
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Canon ES8400V Camcorder Logo
26 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
