Question about Tappan TGF320 Gas Kitchen Range
When i turn the over on the code F-3 appears and it wont start up
  • 794 Answers
Hi melissa_g638,
To fix this error, you need to check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
2003 chevrolet van 1500 wont start
use OBD II scanner. if there is a code in the pcm, it wil point you in the right direction. if not, go back to old school diagnostics. check for spark, check fuel pressure, check compression. if these appear ok, check timing.
Apr 14, 2013 | 2003 Chevrolet Express
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Air compressor wont come on after freon got low how do i get it bac on to charge the system to add more keeps saying (a/c low off)
1.Turn key to on position but do not start engine. 2.Press warmer and off button at same time until screen changes. 3.Press " FAN LOW " until ACM appears. 4.Press " FAN HI " until ACM codes appears. 5.Press " FAN LOW " until clear ACM codes appears. 6.Press " FAN HI " until codes clear is on the screen.
If all is in order the compressor should come on at this point when engine is started. I have never tried this but found information in trouble shoot guide for 1998 Deville Cadillacs. Hope it works for you. Good luck.
Aug 17, 2010 | 1998 Cadillac DeVille
Gud day 2 u sir, am using konica 7030,Am having this code F26-3 pls what do i do? Thanks
F-26-3 means the machine was not recognize the devloper, try to reset, go to 36 mode (turn off machine press 3&6 buttons simultaneously, release 3&6 when the screen appears, select NO.1 HV, then search for L detection.. then start. if it wont work replace devleper then repeat the prcedure
Aug 15, 2010 | Konica Minolta DiALTA Di200 Copier
Error code SC548 wont let me do anything.
please follow the instruction and you will reset the copier:
press the follow keys in order:
1. press the yellow key[c] (clear)
2. press 1-0-7 on the number pad
3.press and hold it pressed the red key [c] (stop)
4.When on the screen will appear other menu different from the usual turn off the machine from the main switch (the red switch) and then turn it on after 5 seconds.
Please answer do this is helpful for we to know if is needed some more information.(if this was not helpful you will need to write the machine model number)
Jan 22, 2010 | Office Equipment & Supplies
Chevy cavalier wont start randomly! makes one click and a humm sound my lights come on the radio comes on but the car just wont start, ive had battery replaced along with the ignition switch, fuel pump,...
Ok then, from your description and the
make/model/year of the car you have there,
it appears you've reset the VATS.
The car's security immobilizer
reader at the key switch
does not recognize the coded
chip in the ignition key any longer.
You can try to put the key
in the ignition, turn to the on position &
wait at least 10 min like that.
(Do not turn off the key switch before
10 minutes as elapsed!)
Once done, the key is re-programmed and
should allow the fuel injectors to work again.
The car would start now if corrected.
In some cases, the VATS (GM'S VEHICLE ANTI THEFT SYSTEM)
will re learn the code this way, and will then
allow the restart, however if this does not work,
then you can simply tow it to any GM vehicle dealer
to have the service department re code it.
There is a permanent solution though.
Adding the PLJX Self learning Bypass module (59.95)
will bypass the PASSLOCK system in your vehicle
for good. See this at www.PASSLOCK2.com
Good luck I hope method 1 does the trick!
Here is the 30 min relearn:
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Dec 22, 2009 | 2003 Chevrolet Cavalier
My nokia 6600 wont start how will i reformat it
it wont start like it wont turn on? or it wont continue booting?
anyway here's the way to format your phone
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Jan 14, 2009 | Nokia 6600
Radio Locked 1999 GMC Jimmy
If you press and hold the 1&4 or 2&3 buttons together for 6 - 9 seconds a 3 digit number appears (xxx). Hold the AM FM button a second 3 digit number appears (yyy)
Call 1800-537-5140 when recording starts press 106010*xxxyyy* and it will give you your code
My 97 jimmy wont give me my second 3 digit code but good luck
Dec 20, 2008 | 1998 GMC Jimmy
Tappan TGF320 Gas Kitchen Range Logo
47 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
