SOURCE: ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
SOURCE: Water forming in fridge part of fridge/freezer
check your gasket on the refrigeratordoor with a dollar bill. it should have resistance when pulled out from between the gasket and door. if not then replace the gasket. or the drain tube in the freezer compoartment is clogged up and not draining properly. good luck and contqact me if theres more to the problem ok.
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
SOURCE: every thing in our freezer is melting and the fridge is barely
take the back cover off and then clean the condenser coil on the unit. that will lower the head pressure whiuch in turn will lower the suction temperature.
SOURCE: GE TFX20SA back wall of freezer freezing (snow
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
