Question about Proform Drive Motor Choke Treadmill
Why does the choke on my Pro-Form 520X treadmill smell hot?
SOURCE: Treadmill stops running
If you don't have the manual, see if the proform website has a PDF version available for download. They seem to have a lot of past models available. On our system (ProForm T10.0, PFTL0505.0) an E2 error meant the belt speed (according to the sensor) was too slow. The treadmill should come up to the selected speed within 7 seconds or this error is triggered.
Icon service turned out to be knowledgable and fair, although they can be hard to get ahold of on the phone. If you hold too long, then you are given a chance to enter your phone number. I had to contact them several times, and they did call me back each time I left my number.
Unfortunately several things can cause the belt not to run or not run well, so start with the easiest to fix items first like lubrication and tension adjustment (get a manual from the website if you don't have one--it covers this adjustment). Maybe clean the speed sensor wheel with compressed air or a q-tip (our model had a slotted wheel on the drive shaft which spins through an LED light detector).
If the speed is off, try calibrating the treadmill. Icon service can tell you how to do it (it's not in the manual).
Posted on Jan 12, 2009
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
buffalonyman
  • 1865 Answers
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Posted on Aug 29, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
bwinton
  • 83 Answers
SOURCE: treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
Latch knob will not release on pro-form 1450
PuPush up on the fold-up portion then pull.
Jan 03, 2014 | Exercise & Fitness
Pro form 635cw stops after 10-12 minutes.
please see the video and fix it .This happen because the lack of maintenance schedule in your equipment,God bless you
Apr 04, 2013 | Treadmill Doctor Proform 635Cw Treadmill...
Treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Sep 19, 2012 | Proform Pro - Form Treadmill 705 CST
Pro form 835qt stops working after a few min. Took off cover and it smells very hot in the control section. What looks like a transformer seems to be putting out the most heat. any ideas?
that part is on the incline motor if that is hot and you are not inclining then something is wrong with the incline motor or the controller board
Mar 10, 2011 | Proform Exercise & Fitness
I have a Pro Form 750 CS. It runs great, but when it running with the incline, it has a burning smell.
one of the motors is burning out or over heating .take hood off then run you will see ands smell which one is in failure
Mar 07, 2011 | Proform Exercise & Fitness
I have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Dec 22, 2009 | Exercise & Fitness
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Proform Drive Motor Choke Treadmill Logo
325 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
