Question about Sub-Zero Refrigerators
I have a sub zero 550/511 and noticed recently that it doesn't ever shut off, as it used to. The other day I cleaned out some ice that had accumulated beneath the vegetable drawers, and noticed a thermostat bulb mounted on the back wall. Near it was a stray metal wire hanging out from beneath the back wall casement. Could the thermostat be broken and causing my problem? If so, is it easy to replace. Thanks Michael Segell
  • 198 Answers
SOURCE: water accumulation under vegetable drawer model
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Posted on Jun 17, 2008
SOURCE: Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
Posted on Nov 12, 2008
SOURCE: Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Posted on Apr 14, 2009
  • 744 Answers
SOURCE: I have a sub zero 611 and water is accumulating
sounds like you have a blocked drain tube....when defrost system kicks in the melted water runs down a tube into a tray adjacent to the compressor and is evaporated by the heat. when the tube becomes blocked the water has nowhere else to go except overflowing and out through the refridge vent down the back and onto the floor of the refridge.
If you are hand with tools i can explain a procedure to fix this problem, If not call a service guy :)
Posted on Jun 23, 2009
SOURCE: Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
Sub Zero 690 ice make not working after tripping breaker
Is the "ice" icon displayed on the screen? you have to turn on ice production on a Sub-Zero
Aug 30, 2016 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
Our ice maker makes a little ice , and it doesn't drop. What is wrong with that? Also the house was built in 2005, but the previous owner hasn't live here. How come it can be that? Thanks
Turning the fridge temp down a degree or two will create more ice and at a faster pace. It usually takes a few hours to notice the increase in ice production.
Jul 04, 2011 | Sub-Zero 695/O Side by Side Refrigerator
The ice maker in my 550 bottom drawer makes ice but does not shut off before spilling a few ice cubes into the drawer. In lookin at teh metal arm that exrendes into the tray it appears that it may not...
good day,
Sub Zero makes both a wire device and on some models a round rubber device that slides over the ice level arm. If you don't have one on your model, call your local appliance parts house and check with them. The wire model just clips on, the rubber style has a **** in it. The purpose is to shut the ice maker off before it becomes too full, causing your problem.
Nov 22, 2010 | Sub-Zero Bottom Freezer Refrigerator
My sub-zero refrigerator setting was on 7 when i moved into my home 4 years ago and I noticed recently it was not cooling enough so first i cleaned the filter area but it still seamed not to be as cool as...
Good day,
The important thing is to make sure the condenser coil is cleaned properly.
It is critical to the operation of the machine.
The coil is too thick to be vacuumed or brushed out. It is necessary, to blow the dirt out completely.
Service techs use compressed air with a hose, but a good substitute is a good push/pull shop vac with a crevice tool attachment. It's messy and dirty, but necessary.
After that the setting on the control should be set where you like it.
The control may be going out of calibration due to age, and as long as it can be set to any number that works, then that is O.K.
Although seemingly high, 7 seems to be the settings most Sub Zero owners like.
Thank you for using FixYa
Jan 21, 2010 | Sub-Zero 561 / F
Under counter sub zero ice machine. stoped making ice
Try this! Clean water tube, Check Ice sensor ( small wire (red tip) set to close to ice plate ) To close ,no build up sets off to soon.
Dec 11, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
Feb 28, 2008 | Sub-Zero 632 / S
Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Oct 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
88 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
