Question about Minolta DiALTA Di250 All-In-One Laser Printer
C0500 - Minolta DiALTA Di250 All-In-One Laser Printer
  • 1,110 Answers
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. This is where the meter count is and the "slide" that controls how dark/bright your display screen is. Now just to the left or front side of where the slide is you will see a small hole in the panel. You need a small paper clip or a tooth pick to insert into the hole. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see something that resembles the copier sitting on top of the globe. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. At the lower left is "Trouble Reset" - Press this box to reset the code. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
This procedure works on the Di250 Di250F Di251 Di251F Di350 Di350F Di351 Di351F.
Please provide positive feedback if I was helpful.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 15, 2010
  • fola adewusi Oct 07, 2011
    thanks so much! u saved me. it was very easy. i was begining to get worried.
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Oct 13, 2008 | Minolta DiALTA Di250 All-In-One Laser...
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
C0500 malfuntion
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperatu
Dec 28, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta DiALTA Di250 All-In-One Laser Printer Logo
467 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
