Question about Hoover U5117-900 Bagged Upright Vacuum
Height adjustment doesn't seem to work. - Hoover U5117-900 Bagged Upright Vacuum
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 19, 2013 | Bissell 3576 CleanView II Bagless Upright...
Height Adjustment on Hoover Wind Tunnel doesn't seem to do the job.
You changed the belt that drives the brushroll, it is a flat stretch belt. The V belt also should be replaced every year or two max. It will not be stretched out like the flat belt but with normal use the side of the v will of wear off and the belt will be a little thinner which can cause it to slip on the pulley. The V belt drives the transmission. The flat belt goes from the transmission to drive the brushroll. The burning smell could come from the V belt if it's slipping real bad.
Mar 15, 2017 | Vacuums
How can you do a height adjustment on Oreck XL Series vacuum
Oreck makes two different attachments for putting on the bottom of your vacuum to raise it up. They have one for the older Classic styles and one for the newer XL models. This is the only way you can raise the brush on an Oreck.
Jul 18, 2012 | Oreck Vacuums
My dyson vacuum adjustment height is not working
Your DC07 is engineered to automatically adjust to different carpet piles and floor surfaces. If you're concerned that it doesn't seem to be doing this as normal, please follow the steps shown in our online support guide to make sure everything is correct with the machine:
http://www.dyson.com/support/help.asp?article=4&product=DC07-SY-HEPA_US
If you're still concerned about your Dyson after running through the troubleshooting guide, please get in touch with us directly so we can help - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 05, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Dyson 07
when using the hoover it doesn't seem to adjust it's height automatically i have to either put some pressure on the front plate or turn brush off which sometimes seems to work, i have checked filters renewed both the handle hose and the hose under the plate as they both had holes in, but it still hasn't improved
Jan 05, 2008 | Vacuums
Hoover U5117-900 Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
