How can i get an addmaster IJ6080 printer to print single space lines instead of double space?
  • raj7827m Jun 19, 2008
    i am installed the printer that is zebra z4mplus it is a barcode printer in the the display printer is idle but when i give test page print then no more printout is comming form the printer but when i give test print command the printer sencer is working
I have a barcode printer zebra z4mplus
i installed the printer but i am not able to print form it suggest me how can i resolved the issue
Posted on Jun 19, 2008
Printer double spaces between lines
That is a setting in your printer setup menu under options or advanced. Page set up should come up under advanced or as its own tab.
Apr 09, 2014 | Citizen iDP-3550 Matrix Printer
Will IJ 6080 XP drivers work for Windows 7?
Hi There
No it will not work sorry.
You will need to find a Windows 7 Driver for it, But this could be hard to find as they not made many drivers for the windows 7.
Some times if you could find a Vista driver for your printer it may work it.
All The Best: Pineworks
Apr 07, 2010 | Alps Addmaster IJ6080 InkJet Label Printer
How do I adjust the line spacings
Just go to FORMAT and select LINE and SPACING option..there you should select 1.5 spacing....this will solve your problem..
Jun 22, 2009 | OKI MICROLINE 3320 Matrix Printer
New doc spacing automatically goes to double.
use the shift + enter to get single line. else you need to save a template that includes single line.
Feb 23, 2009 | Microsoft Office Professional 2007 Full...
HP laserjet p2015 printing problem
How old id the printer. What OS do you use. What driver version do you have and does the printer have any accessories fitted?
Jul 07, 2008 | HP LaserJet P2015 Printer
Single space
It may be following orders ;-) check the software you are using to see if the printer is being told that you want double spacing.
Jun 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Jan 14, 2008 | Citizen 3550 Matrix Printer
How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dec 27, 2007 | Office Equipment & Supplies
Documents in single space print in double space
There may be a dip switch somewhere on the printer which enables/disables the extra linefeed. If both CR (carriage return) & LF (linefeed) are both enabled, you will get the double-spacing. In years past, I've run a few different Epson dot matrix printers, and seems like they had such a dip switch. Also, on the software end, you may be able to disable either CR or LF- check in your printer driver software.
Apr 16, 2007 | Epson LX-300 Matrix Printer
139 people viewed this question
