Question about Panasonic PT-56DLX75 56" HDTV
We turn it on and it doesn't power up. We have checked the bulb, it looks fine, the remote batteries are fresh, all connections are good any ideas?
    New Friend:
  • 4 Answers
New lamp bulb, still doesn't light up.
Posted on Sep 07, 2013
HOW CAN I TROUBLESHOOT THE REMOTE CONTROL FOR THIS SYSTEM?
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
Nov 16, 2015 | Sanyo New Original KHS1251 Remote Control
Will not turn on
Try first changing the battery and then check if it will now power on...
Oct 31, 2008 | Logitech Harmony 520 LCD Remote Control
Doesn`t work with remote control
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts, inside the battery compartment, before inserting new batteries. If you wish to get more details about how to check a remote control, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Soyo SYTPT3227AB 32 in. LCD TV
Blown bulb
Ideas? Yep. Shut down fan power at the source (fuse, breaker, etc.). Turn on fan power again. You should be back in operation
Jun 14, 2013 | Monte Carlo Manhattan Ceiling Fan
Vizio remote XRT302 is not working after 3 weeks of use. Any ideas besides changing the batteries?
TRY FRESH HIT BATTERIES FIRST!
I WAS ABOUT TO ORDER A NEW REMOTE, then read this thread. I went back and messed around with the remote. I checked the batteries and the had power but wee in the low yellow reading. I put in fresh hot new ones BOOM it was working just fine.
Thanks for all y'allZ commits.
Sam B.
Apr 06, 2013 | Televison & Video
Right brake light doesn't work with lights on. Switched R bulb and socket to left, and it works. Radio also goes off when headlights r applied. But radio comes on when I turn dimmer switch all the
check for power and ground. One should be at battery voltage and the other ground. Somet5imes ground can't handle the current from the bulb so try to make a connection to ground. I try to either use the fuel tank or run a wire from the battery.
Second reason the turn signal switch can go bad and keep the battery voltage from reaching the bulb. I will also assume you checked the bulb on the other side that you know works fine. I use electrical contact cleaner inside turn signal switch. Move the lever
rapidly to clear any possible dirt.
Mage Talesin
Jan 17, 2013 | 1997 Dodge Dakota
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
My mazda 6 2.3L wont start. I checked the battery and she's strong. When I put the key in the ignition and turn it so the lights and radio would come on, every things fine. When I try to turn it over I...
This is an indication that you have a bad or loose connection at the battery. Check the cable ends on the battery and clean them of any green looking stuff. Make sure all connection are tight at the battery.
Sep 10, 2011 | Mazda MAZDA6 Cars & Trucks
My 2000 ford focus will not start. It does not make any noise but the lights go on. It doesn't even turn over. My mechanic disconnected the remote car starter and that seemed to help but now I'm...
If it's not a dead battery, it could have bad connections. Check battery connections for tightness
Check the battery cable connection on the start solenoid, usually very near the battery. Check all wires on the sloenoid.
Check solenoid cable to starter for tightness at both ends.
If starter & battere are good it has to be one of above'
Good Luck
Jun 30, 2011 | 2004 Ford Focus
Panasonic PT-56DLX75 56" HDTV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
