Question about Dell Dimension E510 PC Desktop
Replacing the battery on dell e510 - floppy disk drive not present
I replaced the battery. i got an error message saying floppy disk drive not present. tried to disable all floppy drives as i saw as a solution on another site. after doing so, got an error message saying hard drives could not be found. please help! still paying on this computer but warranty is expired.
  • 1 more comment
  • twinkie0225 Jun 19, 2008
    i'm sorry. i should have been more clear. i replaced the cmos/bios battery in a dell e510 desktop. i pressed f2 and went to the bios screen. i disabled the floppy (the computer doesn't have one to begin with). after that is gives a new error message about a hard drive not present.
    i did like you said. the hard drive passed. now it doesn't go to the dell screen at all. it goes to the windows xp screen like it's loading then the screen goes black. the computer stays on but nothing is on the monitor. more suggestions?
    please help, anything would be wonderful
  • twinkie0225 Jun 23, 2008
    I ran the check of the hard drive and it said pass. After i went into bios and changed the diskette drive to off and drives 0-3 to on, I received an error message:
    drive 1 not found: serial ata, sata - 2
    drive 3 not found: parallel ata, pata - 1 (pri ide slave)
    I will try to set drive 0 to sata (although I think it already is) and the flash cache (can I find that in bios?).
    Novelist:
  • 119 Answers
Try this
turn on your computer when you see the dell logo press f2
once in the bios screen check drive and see if your hard drive0 will give you your hard drive details at the lower right side of the page
you can also do some diagostics by pressing f12 when you see the dell logo and go to diagnostics. if it passes that means there is nothing wrong with your hard drive.
if the hard drive appears correctly
be sure that the drive0 is in sata or sata is highlighted on the right side of the screen
Posted on Jun 19, 2008
  • francisco de mesa
    francisco de mesa Jun 20, 2008
    place your hard drive in the bios boot sequence as the number 1 drive
    then also in bios screen go to drives and select drive 0 and make sure it is set to sata
    then go flash cache and set it to stop
  • 20 Answers
Replacing a laptop battery should not make a drive all of a sudden not appear.
You will have to enter the BIOS of the computer by hitting the required key stated at the first screen when Turning on the computer (usual located at the very bottom, it's almost always F2 or Tab or Delete)
Once in the BIOS the very first screen visible to you should tell you the drives hooked up to the machine VIA IDE or SATA. See if your HDD is located there.
Type password and I have replaced the battery in my computer.The message I am receiving on the screen is Diskette drive 0 seek failure.
For the diskette drive 0 seek failure, does the computer skip past this error without difficulty ? If it does, then you may ignore it. It is caused probably by your replacing the battery having reset the BIOS which is thinking now it should find a floppy disk to boot from. If you haven't a floppy disk, or have floppy disk drive you will get this message. I do, but I ignore it. When you power up, you could try entering the BIOS setup, by pressing for example, the esc, F1, F2 or F8 keys - for your model I don't know which, you may find out from the internet, your manuals, or the Dell website/help or support - repetitively before the computer starts,
( from Dell support - "You can enter the system BIOS or Setup on a Dell PC by pressing F2 at the Dell loading screen").and somewhere the BIOS setup there should be the boot order change this to CD first (no CD inserted unless it is bootable), then USB if available (no media USB inserted, some USB devices are ok), the HDD. You should not set HDD first because this will give you big problems if it goes wrong and you need to boot from somewhere else. Put floppy disk after HDD and the message will disappear.
I don't know about the password issue. I suggest you contact Dell support on this topic.
You may find the following links helpful
21.June.2015 https://answers.yahoo.com/question/index;_ylt=A9mSs2LW34ZVSAcAzONLBQx.;_ylu=X3oDMTByaW11dnNvBGNvbG8DaXIyBHBvcwMxBHZ0aWQDBHNlYwNzcg--?qid=20080113054551AAsulsm&p=enter%20bos%20on%20dell%20dimension%203000
Knowledge Base
and have a good look through this page
Product Support
and the associated links. In subsequent efforts try joining the Dell Users group (or what ever it's called, probably accessible from the link above and asking there, it might be a common issue that many have experienced and there are well known solutions to)
Sorry not to have been able to answer your questions directly, and to have pointed you in the direction of lots of reading, but I hope the links prove to be quickly useful
Jun 09, 2015 | Dell Dimension 3000 PC Desktop
The screen says none system disk or disk eror replace and strike any key when ready.we have tried everything and it dont do anything.can you help me ...
I would make sure there is no floppy disk inside the floppy disk drive.
This error message is typical for a Windows system when it's trying to boot from a not bootable floppy disk.
Remove the floppy disk and try to reboot.
I hope this will solve your problem
Mar 28, 2011 | Compaq Computers & Internet
Alright i have a dell dimension E510 and i have no floppy disk. and it is saying that i have a floppy diskette seek failure . then at the bottom it also says alert! previous attempts at booting this system...
You will need to go into setup when you boot the computer and in that menu scroll down to the floppy disk and disable it. That should solve it. var fctb_tool=null; function FCTB_Init_c708739f53a84b7887b9dbecd89fa685(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2800a0bea82c4f8db0c9352dc6041606(t) { fctb_tool=t; start(fctb_tool); }
Dec 26, 2010 | Computers & Internet
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
On a dell e510 at start up i get to boot and then recieve the message....floppy diskette seeks failure....
This means that your pc regognize a floppy disk in the drive, tried to boot from this floppy and the floppy is not bootable. You have 2 solutions:
  1. Remove the diskete from the floppy drive and restart. Assuming that your hard disk is ok the pc will boot normally.
  2. You have to enter the bios and change the boot order. Doing this you will change the boot priority and the pc will try to boot from the hard disk before the floppy drive. Since this solution it's more complicated from the first one, I suggest you to follow this way in case you are familiar with bios.
In case of a problem or clarification, or more details for the 2nd solution, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | Dell Dimension™ E510 PC Desktop
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
The CMOS/BIOS battery has died and needs replacing.
The battery is located on the motherboard inside the case of the computer.
To replace the battery you'll have to open the case up and replace the battery. It looks like this >>>
Once you have replaced this battery and restarted your computer you will need to access the BIOS to set the date, time and also tell the computers BIOS that the floppy drive is not there and to set the boot order of the computer.
Once you have done all this you should not get that message again for a good few years.
Regards.
Jul 16, 2010 | Dell Computers & Internet
Dell disk drive not working
check bios if fdd is detected.
tried any other fd.
replace floppy disk drive.
wait? is this disk drive like floppy or the HDD?
Oct 07, 2009 | Dell Latitude D520 Battery PC Notebook
New Dell Internal / External USB Floppy Drive 1.44Mb
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
I am replacing the hard drive in my Dell Dimension L866r
Do you have a floppy drive in the drive if so remove it. Also turn off your floppy drive or just remove it completely it could be bad sending false info to the main board saying there is floppy drive in the computer. Also try and turn the drive off in the BIOS
Jan 16, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Dell Dimension E510 PC Desktop Logo
    661 people viewed this question
    Alun Cox
