Question about Amana ABB1927DE Bottom Freezer Refrigerator
I have a Amana refrigerator model SXD22S2W and no cold I change the defrost thermostat and steel no work only make ice around the thermostat and under the little fan next to the thermostat what i have to check now ?
  • Amana Master
  • 2,696 Answers
Remove the bottom kick plate and see if you have a timer or a computer board called an adaptive defrost board,if there's a timer turn the knob on it and see if the heater comes on,if it does then you have a bad timer,if it has the adaptive defrost there should be a tech sheet in the kick plate,look at it and it will tell you how to put your machine into defrost,also you changed out the thermostat already,shut down the machine,remove the freezer wall,unplug the heater and with a meter read out the heater,if it's good change out the timer or adaptive defrost board and you should be all set,also with that machine i need the p number,it's where the model number is,i looked up your model number but alot of machines popped up,it looks like you have a calrod heater and they hardly ever go bad so check for a timer or adaptive defrost board,if it's a timer turn the knob on it slowly till it clicks,it will be in defrost,remove the freezer wall and see if the heater is on or you can look to see if it's glowing or look for melting ice and you'll know the heater is on,if it has the board,look at the tech sheet,it will tell you how to put it into defrost,do what it says,when you open the freezer door if the fan is still blowing then the board is bad because the fan won't blow if it's in defrost on the older machines,let me know what you find
Posted on Nov 17, 2010
  • Sal De Nov 18, 2010
    i'm reading what you wrote again and i think you're saying that only the top of the coil is cold and there's no frost pattern anywhere else on the evap coil,if so then you have a freon leak in the system and you need a new machine,i thought you were explaining a defrost problem but if only the top of the coil is freezing then like i said you have a leak in the system and it would be to much to repair,if the coil is icing up on you then do what i wrote before,let me know how you make out
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer is not defrosting. I have tried changing the control settings, but that doesn't help. There is ice coverering about 1/3 of the freezer rear and is an inch or more thick. I have had the...
Freezer defrost coil is open and in need of replacement.
Go to attached site for part number and replacement/repair. If you get number of part, check with ebay for a cheaper price. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Amana ATB2232MR Top Freezer Refrigerator...
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer is partially freezing
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Door open all day Amana SXD22S2w
the evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana bottom freezer, model BX20S5E that is not cooling properly in either compartment. I have replaced both the defrost thermostat and defrost timer (new). Still no change... what I do notice is...
check door gaskets and see if problem is moisture,or air gate to fridge compartment not working properly.I would recomend verifying defrost cycle is working by turing defrost timer to defrost cycle,it will click when engaged when unit is frozen and heater should come on if all is well,if not heater is probably culpret if the rest is new.
Apr 09, 2009 | Amana ARB8057CSL Bottom Freezer...
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
348 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
