Question about Microwave Ovens
I have been given a Norfrost Ice Chef Chest Freezer and I need a user manual.
Have magic chef microwave model mcd795sw need 50% power. How do I do thi
Hello, Bobbie -
You should be able to find the instructions for setting your model of Magic Chef microwave in the user's manual. My guess is that you do not have a user's manual for the MCD795SW.
This is the link to the page on ManualsOnline.com where you can open the PDF file for free and choose to save the manual:
http://kitchen.manualsonline.com/manuals/mfg/magic_chef/mcd795sw_1.html
See Page 7 of the manual to learn how to choose the power level you want.
Note: You will need Adobe Reader software (free) because the manual is in PDF format. When you save the manual document, be sure you name the file you save it to in your Documents folder with a file name you can find easily - something like: Magic Chef Microwave Manual. You will probably want to print the manual for easy reference.
Best wishes.
Jan 16, 2018 | Magic Chef Microwave Ovens
Where is light bulb on magic chef microwave oven model # MCM990ST?
Free User Manuals and Owners Guides ManualsOnline com
good evening, this site is a good place to look, in case the manual is not to be found. I got my washing machine manual there, after having looked for the printed one without success.
kolbrun
Feb 01, 2015 | Magic Chef Microwave Ovens
I NEED TO KNOW HOW TO WORK THE OVEN
Good evening
if you can not find the manual, try this and find the manual you need.
kolbrun
Oct 11, 2014 | Magic Chef Microwave Ovens
I was recently given an old Magic Chef MCM980ARW microwave. Have looked but cannot find a manual for it. Does anyone know where this may be available?
You can probably find the manual for a similar model that's close enough here.
For more help from Magic Chef / Ewave see here or their contact page or order it here.
Oct 16, 2011 | Magic Chef CMV1000B Microwave Oven
I want to defrost my GE chest freezer but i do not know where the drain is
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Jul 24, 2011 | General Electric Microwave Ovens
I have inherited a Kenwook Chef with various attachments that I would like an instruction manual for.
Try this site. It even explains how to make Ice Cream with your Chef, mmmmmm ice cream...
http://www.kenwoodworld.com/uk/Products/Kitchen-Machines/
I'm off to make some in my Kenwood Chef now.
Dec 14, 2010 | Microwave Ovens
I have a skandiluxe chest freezer and the orange light is on - is this right?
On my Skandiluxe CF309 chest freezer, the ORANGE LIGHT IS FAST FREEZE and should be depressed to quick freeze when adding newly bought items as the temperature will go up when you've opened the lid for prolonged periods. This is also used to drop the temperature when restoring after defrosting. REMEMBER TO TURN THIS OFF. Also, take note of the gauge in the inside of the freezer which tells you which setting to switch the dial to according to how full the freezer is, and therefore the most energy-efficient setting.
The red light is the warning or "alarm" and will light up when the temperature is too warm.
The green light is a "control" light and I can't remember what this is for, but I don't recall seeing it on in the 15yrs or so that I've had the freezer.
TO DEFROST:
(The drain comes out directly underneath the drain hole and there is no hose. Not a very helpful design. I found that if you tip the freezer forward and scoop out as much water as you can, then mop up the rest with a large bath towel, it should do the job.
BTW if you are planning to defrost the freezer (or any freezer for that matter), once you've switched it off, if you have access to a hand-held steamer, and place something like an empty plastic box to catch the ice (we used an unused litter tray as it's the perfect size to catch all the ice in an upright freezer), it saves a significant amount of time. If you don't have one, it's worth investing in a cheap one with the squeegee function so you can do all the nitty-gritty jobs around the house including the windows in no time and no elbow grease at all !!
Aug 12, 2010 | Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
I need a user manual for a Magic Chef Microwave/Toaster Oven, Model MCT9E1ST.
I found the original user's manual that came with the microwave. Thanks for your assistance.
Mar 25, 2009 | Magic Microwave Ovens
Microwave Ovens Logo
229 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
