Question about GE Refrigerators
GE PFSS6PKW display shows "88" on freezer side and
My fridge had the same prob thank you very much this really works i pressed the energy and alarm for 10 seconds and works PERFECT
Posted on May 10, 2011
  • Art Manalo
    Art Manalo Oct 13, 2013
    Thank you for posting this solution! It WORKED! THANK YOU!
  • Anonymous May 09, 2015
    Thanks so much that did the trick!
I am having the same problem after the power was turned off and then reconnected. Have you had any luck finding the source of the problem?
Posted on Nov 20, 2010
  • 5 more comments
  • ahotcoco Apr 04, 2011
    Same problem...what worked?
  • Fwstroker Apr 11, 2011
    Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
  • Frenchpw Apr 15, 2011
    Thanks so much for the reset procedure. It worked great
  • suffolksteph May 31, 2011
    THANK YOU SO MUCH! This worked PERFECTLY!! We searched for 25 minutes for an answer to this question and EVERY answer we found was "Replace the control panel." You just saved us SO much money. THANK YOU.
    Search keywords: GE Profile PFSS6pkw side by side ge profile display locked up ge profile french door screen reads 88 82 reset control panel on ge profile stainless steel power outage
  • davemmons Aug 08, 2011
    I had the same problem. Tried this and it worked perfectly. Thanks
  • cudalova8
    cudalova8 Apr 17, 2013
    So glad I finally found this! It worked! How did you ever figure this out? Glad I didn't spend a whole lot of money on a repair service :)
  • Elijah Szasz
    Elijah Szasz Oct 01, 2013
    Perfect. Thank you so much.
YES it worked!
Posted on Aug 26, 2013
I have a GE side by side with bottom freezer unit. The display panel that controls fridge and freezer temps and controls whether you want ice or water onlys shows 88 88. Tried a 30 sec then 5 minute p
If it is still under warranty call for service right away. It could be the compressor going bad which costs a lot of money. Sometimes almost the same cost or half the cost of a new refrigerator.
Oct 26, 2014 | Refrigerators
How to reset Panel for PFSS6PKW bottom freezer GE Profile Refrigerator? When power went off display is just showing 88 88.
Try pressing and holding the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 or 15 seconds. It should give you and audible beep and reset the panel.
Oct 16, 2014 | Refrigerators
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
GE PFSS6PKW Displays 8888
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
May 10, 2010 | GE PFSS6PKSS
Panel showing 88 88
You can try unplugging , wait a few minutes , and plugging back in . If that doesn't work , then the main control board , located on the back of the refrig ( behind an 8 " X 10 " panel ) , was damaged by the power surge , and needs to be replaced .
Nov 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
Sep 19, 2009 | GE Refrigerators
Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Sep 12, 2008 | Samsung Refrigerators
Refrigerators Logo
1,752 people viewed this question
Top Refrigerators Experts
KJ4QOB
Da Doc
Jim Akins
