Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Re craftsman garage opener 139.53960 cannot get power to eyes from right two terminals as shown on drawing. Eruc
    President:
  • 3,197 Answers
Check to make sure it is wired correctly. Solid white wire from each sensor to terminal #2 and white wire with black tracer to terminal #3. Also check to make sure the wires aren't broken or shorted by staples.
Posted on Nov 15, 2010
Wirering for laser eyes
The solid white wire from each sensor goes to terminal #2 and the white wire with the black trace goes to terminal #3.
Nov 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener that the photo eye stopped working on so I replaced them but upon hooking up the new set they do not light up either. What else may be the problem/solution ??
Make sure the wires are good and not shorted and that they are connected correctly. The solid white wires go to terminal 2 and the white wires with the black tracer go to terminal 3.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: i'm reinstalling my garage door opener because the...
Terminal #1 - White wire with red tracer from wall control
Terminal #2 - Three solid white wires. One from wall control and one from each of the door sensors.
Terminal #3 - Two white wires with black tracer from the door sensors.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need wiring diagram for eyes that control safty device door willnot close by one button push , have to hold button to close , light on opperator has one flash
Safety reversing sensors wire open (broken or disconnected).
Each sensor has a solid white wire and a white wire with black tracer.
The solid white wires go to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do i conect the low volt wire ( the safty eye and the button wire)?
The terminals on the rear of the motor unit are both numbered and color coded. The white wire with the red stripe from the wall control goes to terminal 1. The solid white wire goes to terminal 2. The 2 white wires with the black stripe from the sensors go to terminal 3 and the 2 solid white wires go to terminal 2. You should end up with 1 wire on terminal 1, 3 wires on terminal 2 and 2 wires on terminal 3.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Loose wires
from right to left, 1st pin red wall button 2nd pin white wall button 3rd pin both white photo eye wires 4th pin both black photo eye wires. "if you are trying to rewire the inside of this operator though don't get hurt 150 dollars at sears craftsman is made by liftmaster chamerlain company" ...
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to know wiring scheme on back of garage door opener
join both wires the white one with the white one, and the white with black strip, with the same other, then connect it on the back of the motor the white wires with the white terminal (a white square) and the white with the black strip with the black terminal (a black square) .. check that both leds of sensors are on
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do i order new seeing eyes for my Craftsman Garage opener
try ordering from SEARS. Need to know model number and style of eyes; hard-wired or plug in back. Why do you think you need eyes. They last unless garage floods.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
