Question about Keurig B30 Mini Coffee Maker
My Keurig b30 doesn't brew and squirts hot water instead
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
My Keurig mini sounds like it is brewing, but nothing comes out.
Could be a clog. Open the brew head a insert something small (like a paper clip) into the water output shaft. Swirl it around to break up any deposits there and then run again (without a k-cup). If water comes out but not correctly, repeat cleaning. Also, check to see if hot water is being deposited back into the tank. This will indicate a clog in the output line (line or, more likely, the head). If cleaning the head does not work, then reset the machine by unplugging and plugging back in.
Aug 16, 2014 | Keurig B30 Mini Coffee Maker
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
No water will come thru the coffee. It heats up but doesn t brew
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 24, 2011 | Keurig B30 Mini Coffee Maker
I turn the machine on, add the kcup and water...lights blink but nothing brews, then turns itself off...B30 unit; please advise Thanks
heatman101
May 16, 2011 | Keurig B30 Mini Coffee Maker
I have a new B31 mini plus keurig brewer and I put the water/coffee in, hit the brew button, it flashes red then turns off after about 2 minutes without brewing the coffee.
MODEL B31: I made the mistake of not running water thru the machine first (the Initial cleaning) and was unable to get water to come thru to the K-cup. Reservoir was hot and full and would not come out. SOLUTION: I took a bendy-straw and completely covered the inside needle coming from the top (that goes into the K-cup) and pushed it up with a fair amount of pressure and blew hard into the straw. Then sucked on the straw (BE CAREFUL IF THE WATER IS HOT) and water and some coffee grounds came out. The brewer worked perfectly after this!!
Nov 27, 2010 | Keurig B30 Mini Coffee Maker
Fixable???
If you let me know what color your drip b30 mini is I may have a drip plate for you!
My Email:
help@igotsweetdeals.com
Lets do a quick check on how to brew with this unit;
1 turn power on
2 add water
3 place mug under spout (do not use a clear coffee cup because sensors will not detect a cup)
4 push button
5 wait 3 minutes
6 enjoy your coffee hopefully
Hope this helps you, if you need anything else just email me with the address above.
My website is http://iwantsweetdeals.com/ where I sell Keurig replacement parts
May 26, 2010 | Keurig B30 Mini Coffee Maker
Keurig B30 Mini Coffee Maker Logo
1,675 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
