Question about De Dietrich Ovens
Type 348. Top oven works fine. Bottom oven recirculating fan does not appear to be working. The "fan" in the programme select button no longer spins. But oven heats...
  • 2,299 Answers
This could be one of two things causing this problem. It could either be the fan motor itself or the keypad. You can check voltage at the fan to see if you are getting power to the fan. If you are getting power to the fan and it is not working, then the fan motor itself is bad. If it is not getting power then the keypad is not working to send power to the fan.
Posted on Nov 15, 2010
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Are the top and bottom heating elements both supposed to heat? Only the bottom one is heating except when specifically set on "broil".
Most ovens with top and bottom elements have a multifunction control switch which enables the user to select a certain setting to suit their cooking. The control switch would normally have small pictures of the elements, fan forced function etc, to show what each setting does. Sometimes you may only require the bottom element working and other times you may want/need both.
Feb 14, 2011 | Frigidaire Ovens
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Smeg fan assisted oven not heating up , top oven works fine but main bottom oven doesnt heat up at all but fan working fine many thanks
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Nov 10, 2009 | Ovens
I have a new World twin line gas oven. Model 136/7 or CGK-21515. The programmer has stopped working. No lights, nothing! I have tested the mains supply to the plug and its fuse which are both fine. I have...
Guess you've either solved this, managed without the programmer or bought a new oven. Which ever way it is I still can't give you an answer even now - just sympathy since my identical oven has exactly the same fault. I can't imagine why there would be a cut out for the programmer on the fan circuit board. but I checked my fan board anyway and all appeared to be well.
Oct 28, 2009 | Ovens
Top oven appears to have no power going to it.
Contact an electrician and or the power company.
I believe you have lost the neutral/ground in your power service.
Feb 21, 2009 | Maytag CWE5800A Electric Double Oven
Botom oven not working
Hi
The oven element is probably faulty, I assume the fan is still working.
Nov 23, 2008 | Ovens
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
65 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Chris Hall
Chris Hall
Shehu Pro
Shehu Pro
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
