I have a Vizio VW42LFHDTV10A. What could cause the front indicator light to come on but the set will not power up...??
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Nov 15, 2010
VIZIO tv model VW42LFHDTV10A serial LJPBYBJ1405269 sound good but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 14, 2015 | Vizio VW42LF 42 in. LCD HDTV
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
VIZIO MODEL VW42LFHDTV10A WILL NOT TURN ON. FUSES &VOLTAGES OK
Did you check for the "ON" or "PS ON" signal on the power supply board? It should be around 3.3vdc.This signal comes from the main board, it commands the other sections of the power supply to come on and turn on the TV set. This signal should be present when you press the power button from either the TV or remote. If you are not getting this signal from the main board, you're most likely dealing with a main board failure. If you are dealing with a main board failure, take heed, some Vizio main boards can be expensive.
Sep 04, 2012 | Televison & Video
Can you fix this cracked screen problem on Vizio VW42LFHDTV10A? and no sound?
We used to say have a short service on the patio and buy a new set---damaged panel display unit is more than set cost (if it is even available)
Let it go---when damaged it can instantly damage other boards/parts in the set.
Run a car with no oil and see what happens........
Mar 20, 2012 | Vizio VW42LF 42 in. LCD HDTV
Vizio model VW42LFHDTV10A 42'' LCD has no picture but has power and sound all buttons and remote work. Faded picture appears for about a second and goes blank. Everything else seems normal. I'm wondering...
This problems are those 2 long LCD inverter boards to it left and to it right.These 2 long LCD inverter boards help the LCD picture screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Nov 26, 2010 | Vizio VW42LF 42 in. LCD HDTV
Where can i find a replacement screen for a vizio ...vw42lfhdtv10a
get a look at the connections leading from panel to the inverter they are like laptops and sometimes other brands will fit but never guaranteed find a dead 42" and work from there i hope you luck but never spend 1\3-1\2 what a new set will run ya i have had success in the past doing this as i worked for a leasing company often stuck with these dead sets and they rendered them useless so i gave them CPR and made a profit from it good luck and never touch the internals of a powered up set even unpowered could be fatal so test before you touch and i hope this helps
Nov 17, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Aug 15, 2017 | Vizio GV42L 42 in. LCD Television
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VW42LFHDTV10A
I give you a site for do it your self repair..
http://www.lcd-television-repair.com/
Jul 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
